Im changing the throttle body on my mpi.
Do i need to use sealer?
and if so what stuff??
cheers
Mpi Throttle Body
dmdangermouse
, Jun 06 2009 05:36 PM
6 replies to this topic
Posted 06 June 2009 - 05:36 PM
Posted 06 June 2009 - 07:04 PM
no, it uses a special kind of O-ring.
only needs replacement if damaged
Posted 06 June 2009 - 07:43 PM
thanks alot
Posted 11 June 2009 - 12:13 PM
Can i start the engine without the air filter on to adjust the idle screw?
Posted 11 June 2009 - 03:36 PM
Yep
Posted 12 June 2009 - 03:09 PM
If this is an MPi, the idle is controlled by the ECU. Are you using a scan tool to make the adjustment? Are you just adjusting the throttle cable?
Terry
Terry
Posted 13 June 2009 - 11:08 AM
ive done it now.
The throttle cable was abit too tight and holding the throttle open slightly.
