Where Is Temp Sender For Temp Gauge On 97 Mpi
Posted 06 June 2009 - 11:46 PM
My MPI keeps overheating mainly due to fan failing to operate at the correct time. I have bought 3 Fan sensor switches in the last 12 months, but after a few run outs they fail or work intermittently (leading to partial or full over heats).
The problem is, I only notice these overheats when steam rises from under the bonnet, because the temp gauge still sits on the normal line and never moves (except just after start up).
The fan works in safe mode, but i don't want it running all the time. So i intend to fit a switch direct to the fan, so i can switch it on and off via a dash mounted switch. Obviously for this to work effectively i need to know the correct water temp.
So just need to work out if its the gauge or the sender/sensor that's faulty, but where is the sensor located?
Posted 07 June 2009 - 07:03 AM
the brown one is the only one and it's used for all temperatur related things.
maybe your cooling system won't hold the needed pressure and start to boil
Posted 07 June 2009 - 09:08 AM
I'll have a look at some electrical diagrams and see what i can fathom out.
Thanks Klas
Posted 07 June 2009 - 11:51 AM
i don't know what the ecu is programmed to do with the gauge if the sensor fails, maybe just this, hold the middle and turn on the fan
Posted 07 June 2009 - 12:53 PM
Over heating can be down to several things. Do not assume that because the gauge is reading right that it actualy is.
As has been said, if the cooling system cannot hold the pressure, it will boil over. The black cap on the expantion tank is prime suspect. If the coolant is rusty colour, the cooling system is in desparate need of flushing and then filling correct concentration anti freeze.
For the price of a thermostat and a couple of gaskets, i would change the thermostat. Make sure its 88c.
Also worth looking at the condition of the radiator fins. It there is a lot of corrosion, it wont be anywhere near as efficient as it used to be.
Posted 07 June 2009 - 03:02 PM
The MPi ECU assumes 70c when the sensor has failed outside of either high or low limits. It turns the fan on constantly and runs the engine ever so slightly rich for safety.
The whole cooling system has been replaced, apart from the radiator and temp gauge. Pipes, expansion tank,new expansion cap, water pump, thermostat, fan switch, all gaskets (including head gasket) and fan (8 months ago, which spins the correct way). The radiator ran clear when initially flushed, the whole system was refilled with 50/50 Anti freeze mix. Squeezed all air bubbles out.
But it still overheats, because the fan doesn't kick in despite fitting the 3rd Fan switch in 12 months.
Hence i want to bypass the switch with a manual dash mounted one. Just needed to sort temp readings, but if the ECU switches to default of 70 then can i fit an independent temp sensor somewhere or fit the fan control switch that sits in the pipe and can be set independently of the ecu
Any ideas would be appreciatied
Posted 07 June 2009 - 05:37 PM
do you have any chance to check the real temperatur? the fan is turned on about the same temp the coolant boils without pressure
Posted 07 June 2009 - 06:05 PM
What would be the best way to check the correct temp?
Posted 07 June 2009 - 06:55 PM
i use a mechanical temp gauge with a small probe i can just slip inside a hose connection like the one at the thermostat housing. anything like this will work
Posted 07 June 2009 - 10:19 PM
So can you explain the pressure issue and how it affects the NTC. Will be getting a new expansion cap.
Posted 08 June 2009 - 07:34 AM
the ecu is programed to turn on the fan at around 100°C (don't know exactly, something from 98 - 104°C).
you see that the coolant can boil (without pressure) a bit before the ecu would turn on the fan.
than you see your car overboiling but the ecu is still thinking everything is normal
Posted 08 June 2009 - 07:58 AM
without pressure the coolant boils around 100°C, with pressure it boils around 110-120°C (depending on the exact antifreeze mix and pressure).
fan turns on at 102°C
Posted 08 June 2009 - 04:47 PM
I shall attempt to rectify the pressure problem, firstly by buying a new expansion tank cap
So technically the gauge will work correctly, once i've resumed normal pressure within the system?
Posted 12 June 2009 - 04:13 PM
Edited by Minitrio, 12 June 2009 - 04:14 PM.
