Brake problems
7 replies to this topic
#1 Graham xx
Graham xx
    Just On Tickover
  • 5 posts
Posted 10 September 2005 - 07:39 PM
I'm experiencing a lot of brake peddle travel, I've replaced the callipers with Metro Turbo ones with vented disc’s, all parts are new. I’ve replaced all the flexible hose’s with stainless steel braded ones, brake test at the mot was more than enough. The brakes do work really well, but just want to get rid of the excess travel.
Castle Combe is in 2 weeks and would really like to get this issue sorted before then.
Any help would be appreciated.
#2 minimadjonesy
minimadjonesy
  • 6,417 posts
  • Local Club: SMAC
Posted 10 September 2005 - 07:44 PM
Graham, How did you bleed your brakes? I had this when I had bled them the traditional way but once I used an easibleed It was spot on!
Also does it have a remote servo? if so, one of my club members had this recently and it was where his servo had given up the ghost! he replaced it and it's now ok
If it is your servo I would personally remove it all together! Don't run them on my cars!
#3 nomininolife
nomininolife
  • 982 posts
  • Local Club: Mini Mates
Posted 10 September 2005 - 07:47 PM
Hi Graham
Maybe it is a master cylinder issue, bore diameter?
Just a thought
#4 minimadjonesy
minimadjonesy
  • 6,417 posts
  • Local Club: SMAC
Posted 10 September 2005 - 07:50 PM
could be! maybe the wrong type of cylinder? worn or damaged?
#5 Tarks
Tarks
  • 727 posts
  • Local Club: is there a local club? lol
Posted 10 September 2005 - 08:13 PM
sounds silly but you have adjusted up your rear shoes!!!?
or correct h-brake cable setting ! ? just a quick thought :lol:
#6 Graham xx
Graham xx
    Just On Tickover
  • 5 posts
Posted 10 September 2005 - 08:31 PM
Thanks guys for your help,
The rear cylinders are new when we replaced the sub frame a month ago. I bled the system starting from the brake cylinder furthest away from the master cylinder. I've adjusted the rear brakes, and the master cylinder is new.
This car has always suffered from this problem even before I started replacing items.
I haven't fitted a servo, although I've just reconditioned one and was considering fitting it
#7 minimadjonesy
minimadjonesy
  • 6,417 posts
  • Local Club: SMAC
Posted 11 September 2005 - 01:27 AM
don't bother fitting it! sort out your current issues and run without it!
if you fit it, you'll find it harder to diagnose faults!
#8 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 11 September 2005 - 07:43 AM
is the clevis pin that connects the brake pedal to the master cylinder worn, and the hole in the pedal oval, boththese will increase pedal movememt. Also bleeding brakes always start with the nearest item to cylinder because on dual curcuit systems you will have problems getting the air out. Also you have bleed from the 3 bleed nipples on each caliper
dave
