A few parts i need to know if they will fit my cooper 98/R?
Brake Set
Ball Joint Kit
Track Rod Ends
Rear Brake Shoes
is there anything i could replace while in these areas
all help will be much appreciated
Chris
Will These Parts Fit My Cooper
MiniBonkerz
, Jun 12 2009 07:26 PM
4 replies to this topic
Posted 12 June 2009 - 07:26 PM
Posted 13 June 2009 - 07:33 AM
Those parts should fit ok....... if you are changing all the front hub stuff while you are their its worth changing, or at least checking your front wheel bearings.... as you will have most of it stripped anyway.
Rob
Rob
Posted 13 June 2009 - 09:29 AM
will order some now that way i know there new
Posted 13 June 2009 - 08:02 PM
I would recommend the SURESTOP brake kit from minisport, these are grooved as well as drilled, and they come in at £75 delivered to Uk, rather than those one ebay at £110. All the other ebay parts look ok, and about the right price, however would be cheaper if you could pick them up at a mini show - no VAT or delivery etc...
HTH
Ryan.
HTH
Ryan.
Edited by L400RAS, 13 June 2009 - 08:05 PM.
Posted 17 June 2009 - 11:50 AM
If you were planning to spend £111 on your brakes I'd have a quick search for some metro 4 pots. Although for a new kit you're looking at well over £200, I've seen full kits go for not too much more than those pads and discs. Just a thought, though you'd have to tell your insurance company.
Metro 4 pots
Metro 4 pots
