Where To Buy A Throttle Body?
Posted 15 June 2009 - 09:55 PM
I've just seen a 52mm one on the wood&pickett site but that was up at £160 plus VAT!
Has anyone see one for less? It can be a 48mm one I'm not too bothered.
Mine is a little warped and could do with replacing/upgrading.
Thanks!
amy
Posted 16 June 2009 - 11:16 AM
Posted 16 June 2009 - 11:23 AM
Buy an alloy body - http://www.minisport...ottle_Body.html
Posted 16 June 2009 - 09:11 PM
Don't get a Plastic one, particularly if it's been used!!!
Yep thanks for the suggestions and link but i definitely don't want another plastic one!
Forgot about mini sport, thanks nicksuth. Only a couple of quid more for the uprated alloy one on there too so I may as well get one of those. I'm not sure if the 52mm throttle body will do that much on it's own though
Posted 16 June 2009 - 09:15 PM
Posted 16 June 2009 - 09:16 PM
Posted 16 June 2009 - 09:19 PM
Posted 16 June 2009 - 09:57 PM
I think you'll need some engine tweeks to make use of the 52mm Body, i.e. K&N Cone Filter, Roller Rockers, Ported/Polished Head, LCB, etc. etc., oh, and a PBV to adjust the fuel pressure? Mine also has the Icon Race Chip fitted to give that extra bit.
I had a k&n induction kit thingamijig fitted but swapped back to the original box last week as the noise was a bit too much for my ear drums as a daily drive! All the rest of that stuff is just words to me, I'm still learning I'm sorry. It all sounds very exciting though, maybe I'll get round to doing those sort of things in the future once I've learnt what they all are!
I think there is a 52mm for sale in classifieds.
So there is! thankyou!
Posted 16 June 2009 - 10:15 PM
You might want to ask the "Sprocketmeister"??
Posted 16 June 2009 - 11:03 PM
May have to do a little reading into this/aka ask "the sprocketmeister" guru before I buy the 52mm throttle body then methinks.
Cheers for the heads up!
Posted 17 June 2009 - 01:58 PM
http://www.sucarb.co...l.aspx?Id=33121
After fitting it you will have to reset the throttle sensor, you may be able to do this by pressing the accelerator five times while the ignition is turned on.
Posted 17 June 2009 - 09:35 PM
Posted 18 June 2009 - 10:16 AM
http://cgi.ebay.co.u...ini...:1|294:50
Make me an offer and i'll see what i can do.
Regards
