Induction Noise
#16
Posted 29 June 2009 - 01:35 PM
#17
Posted 29 June 2009 - 01:41 PM
#18
Posted 29 June 2009 - 02:01 PM
#19
Posted 29 June 2009 - 02:43 PM
as for the vid, i will see what i can do!
though do u think extra insulation in the cab would be a good idea (i.e. foam/loft insulation/other sound proofing)?
Edited by finch661, 29 June 2009 - 02:45 PM.
#20
Posted 29 June 2009 - 03:56 PM
oh right, a test would be driving round the block without the filter box then?
No that wouldn't work, under no circumstance should you drive the car without an airbox on.
A test would be to take the airbox off and just look underneath it to see if there's a rubber sealing gasket around the mouth of the carb elbow... you'll know straight away if there is one there.
It can only help, And Whilst you're there you can check to see if all your bulkhead grommets are still in place and in good working order - They let a lot of noise in if they're split or missing. Easy to replace and cheap to buy.
#21
Posted 30 June 2009 - 12:57 PM
oh and all my holes have been filled with some black silicon sealant (works really well)
Edited by finch661, 30 June 2009 - 12:59 PM.
#22
Posted 30 June 2009 - 01:08 PM
Bonnet insulation pads help a considerable amount, Other than that i would suggest maybe the rubber sealing ring is missing from underneath the airbox. It's almost always missing, and seals the airbox to the carb elbow.
what readibly available glue (i.e. something you can buy instore) can you use for these as i tried carpet glue with no sucess lol
half hour worth of running an they fell off lol
#23
Posted 30 June 2009 - 01:29 PM
minispares sell some felt glue i think?
#24
Posted 14 July 2009 - 02:56 PM
#25
Posted 14 July 2009 - 03:59 PM
Urmm if you can get a video it would help, as this could be something not sealing properly.
#26
Posted 14 July 2009 - 04:15 PM
