Timing For A 998
Posted 17 June 2009 - 05:06 PM
cheers
Posted 17 June 2009 - 05:09 PM
(u)1983 to 1987 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . - 8º + 0º -2º BTDC at 1500 rpm
1988 (category C) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . - 10º + 0º -2º BTDC at 1500 rpm
1989-on low-compression . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . - 8º + 0º -2º BTDC at 1500 rpm
1989-on high-compression . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . - 10º + 0º -2º BTDC at 1500 rpm
Just to add thats standard engine spec setting
Think for stage one the fitting instructions from minispares say 5 degrees @ 1000 rpm
Edited by lrostoke, 17 June 2009 - 05:13 PM.
Posted 17 June 2009 - 07:33 PM
What would be the adjustment to be made to the timings shown as a result of running an unleaded head and unleaded fuel on the standard 998 engine?
Roy
Posted 17 June 2009 - 08:01 PM
Posted 17 June 2009 - 08:36 PM
Edited by Cooperman, 17 June 2009 - 08:36 PM.
Posted 17 June 2009 - 08:58 PM
I've just fitted a new 59D4 distributor to my 998 and set it up with a strobe light but struggled to get much more advance than about 8 deg BTDC because of the vacuum advance on the distributor fouling the oil pipe across the front of the engine.
However as it seems to be running fine (easy to start, bright on pick-up, no pinking when under heavy load, no overheating, etc, etc) it seems like adjusted to its maximum is about right.
Just interested to hear what the timing figure should be - must have missed the bit in the Haynes manual about unleaded.
Roy
Posted 17 June 2009 - 09:48 PM
hi, does anybody know what degrees to set a 998, 1988 engine to, i am currently timing it to 8 degrees but im not sure if this is correct
cheers
Check you have your connections the right way round on your coil first
Posted 15 August 2026 - 09:28 PM
But can anyone explain the numbers below
I assume its 10 degrees at 1500rpm but what does the +0° and -2° relate too?
Posted 15 August 2026 - 10:45 PM
It means you can have:
10+0 = 10 as a maximum
10-2 = 8 as a minimum
So set between 8 and 10
Posted Yesterday, 11:06 AM
Thanks mate. Appreciate that, I have a very technical mind can fix almost anything.
Just not too good on translating the manual it appears haha.
