can anyone give me a list of possible problems a stepper motor can cause when not working correctly
thanks
Stepper Motor Problems
gar1380
, Jun 19 2009 03:10 PM
4 replies to this topic
Posted 19 June 2009 - 03:10 PM
Posted 19 June 2009 - 05:54 PM
My car would not idle from cold due to the stepper not moving enough to open the throttle butterfly for the fast idle,changing this for a secondhand replacement cured this problem.
Why do you ask?
Why do you ask?
Posted 19 June 2009 - 09:10 PM
Why do you ask?
got a prob with my spi and cant put my finger on it, so just a process of elimination
Posted 19 June 2009 - 09:24 PM
So what exactly is wrong with your SPI?
Someone on here may have had the same problems and can help you out.
Posted 19 June 2009 - 10:57 PM
ok, just had a full rebuild on the engine 1380, head work, and a gearbox rebuild, off the road for a few months but before that everything was fine, running wise that is, fueling etc, now its throwing out black bits out of the tail which tells me its running way to rich tried the usual but still not sorted, also got a big flat spot when taking off in 1st, it just dies on me unless giving it big revs but dont want to keep that up as i am still running it in.
gareth
