Exhaust Puffing?
10 replies to this topic
#1 rpowell86
rpowell86
  • 55 posts
  • Local Club: MMC
Posted 01 July 2009 - 06:43 PM
Model:City E
Year:1988
My cars been making what can only be described as a rythmic puffing sound.
I dont know how to fix it to be honest becuase I dont know whats causing it.
I Suspect its the carbs not setup as it hasnt been rr'd, but I cant afford it till next month.
Anyone know how to fix this?
Hears a vid (only first 10secs are probs any use)
Thanks,
Ryan
Any non-standard parts that might be involved with the problem?
Stage 1 Kit
Edited by rpowell86, 01 July 2009 - 07:46 PM.
#2 jaydee
jaydee
  • 8,565 posts
Posted 01 July 2009 - 09:47 PM
Mixture too rich at idle, what needle are u running? i bet its an AAU..try setting timing at 5° -1500rpm (vacuum disconnected) and leaning mixtur a bit, but i'm pretty sure you need another needle. A rolling road session would be helpful.
#3 rpowell86
rpowell86
  • 55 posts
  • Local Club: MMC
Posted 02 July 2009 - 06:47 AM
I think I bought a AAU needle for it. Whats is the correct Stage one needle for a 998cc single HS4?
#4 Pauly
Pauly
  • 4,213 posts
Posted 02 July 2009 - 07:58 AM
What airfilter you running? If its a k&n cone then they usually need to richer needle for the carb.
Thought puffing sound from exhaust was when it runs to lean?
Paul.
#5 bmcecosse
bmcecosse
  • 9,699 posts
Posted 02 July 2009 - 08:00 AM
Look at the spark plugs - what colour are they ?
#6 rpowell86
rpowell86
  • 55 posts
  • Local Club: MMC
Posted 02 July 2009 - 08:46 AM
From left to right:
1. Brown (normal)
2. Carbon deposits (runing rich?)
3. No deposits (running lean?)
4. Brown (normal)
Spark plugs changed about 1K ago
Doesnt this suggest Ive got other issues ontop of the current problem though?
What should I try adjusting? It only happens after its warmed up after a few minutes, Ill try adjusting the mixture scew. But is there anything else?
Thanks,
Ryan
Edited by rpowell86, 02 July 2009 - 08:48 AM.
#7 bmcecosse
bmcecosse
  • 9,699 posts
Posted 02 July 2009 - 09:03 AM
Seems to be rich - and probably ring problem on your #2 (which is actually #3 cylinder!!) - weaken it slightly.
#8 jaydee
jaydee
  • 8,565 posts
Posted 02 July 2009 - 09:14 AM
What air filter do you have? Have you setted timing?
If you got a KN ry an AAA needle instead of AAU and weaken mixture, sounds to me you're out of timing (too far advance) and too rich at idle.
#9 rpowell86
rpowell86
  • 55 posts
  • Local Club: MMC
Posted 02 July 2009 - 09:21 AM
Thanks guys!
I have a k&n filter element in the standard box. Ill get myself a AAA needle and give it ago.
Ill look into the timing as I am getting run on too. Is there a guide that shows me how to check my timing? (anything online other than haynes :) )
#10 jaydee
jaydee
  • 8,565 posts
Posted 02 July 2009 - 09:54 AM
Theres a thread here from Dklawson which explain everything about timing, do a little search or PM him..
#11 spiguy
spiguy
  • 1,537 posts
Posted 02 July 2009 - 07:46 PM
Is there a guide that shows me how to check my timing? (anything online other than haynes :thumbsup: )
Sounds like an intermittent misfire to me. Coupled with one plug which you reckon is a bit sooty, I'd say you are getting an intermittent bad spark on that cylinder. Maybe worth trying different plug / lead etc, give everything a clean up in case of any tracking?
I'd swap the plug with one of the others and see if the sooty appearance follows the plug.
