Just A Quick Question
Posted 03 July 2009 - 02:06 PM
its a 998cc 1988 mini mayfair with a few mods taking it up to 48 bhp (measured on a rolling road)
just wondering if this time is any good to be honest. what is the 0-60 time for a standard 998?
i was planning on dropping a 1275 in soon but don't know if it is worth the work.
thanks a lot
Danny.
Posted 03 July 2009 - 02:13 PM
Posted 03 July 2009 - 02:22 PM
yeah i did two runs in oppisite directions, no obvious wind but the road wasnt perfectly flat. i got 16 on the first run n 15 on the way back.
would like to know what the standard time is though, if you or anyone knows it?
it does smoke a fair bit in the top revvs, is this a sign of anything?
i may start a new thread about that if it worth it?
Posted 03 July 2009 - 02:28 PM
Posted 03 July 2009 - 02:33 PM
i was just interested because its nice to know the difference that the work you've put in to it has done i suppose.
when you say 'gear it up' are you taking about making the ratio's higher?
would this make it better on the motorway? because i would love to take it to uni with me but its just so uncomfortable for motorway driving.
also what would doing this involve?
Posted 03 July 2009 - 02:40 PM
Posted 03 July 2009 - 02:50 PM
how much do these tend to cost?
also whats the standard ratio?
Posted 03 July 2009 - 07:32 PM
An original Cooper 998 did it in between 14.5 & 16 seconds in standard form with a quoted 55 bhp and a 3.76:1 diff on 10" wheels.
I recently took the 0-60 time for my Historic Rally Cooper 'S', which is a 1964 car on 10" wheels with a cross-pin diff (not an lsd). It was against a calibrated tacho and it gave 7.4 secs, 7.8 secs and 7.5 secs on 3 runs using only first and second (high revs in 2nd), and 8.3 secs and 8.5 secs using 1st, second and third. This was on the runway of a very flat airfield with minimum wind but in 2 directions. The bhp was last measured as 117 at 6300 rpm at the flywheel, but it also has 102 bhp at 5200 rpm. It is 1310 cc on twin H4 SU's and a 286 cam, etc., with a SC Cr box and SC drops. It would be quicker if I didn't run with a sump guard, full gage, two spare wheels and full rally instrumentation.
The key to the differences are how much wheelspin you get from rest. I have to keep the revs over 3000 even at take off to avoid it falling off the cam, but try to minimise wheelspin at the same time.
Posted 03 July 2009 - 09:46 PM
Yes - fit a lower (numerically) final drive gear set. I just sold (thanks Emma!) a 3.1/1 gear set - that's the ideal ratio for a warmed up 998. To fit really means taking the engine + box out, although it 'can' - with considerable difficulty - be done in place.
Which would normally be called a higher final drive....... ie, 3.44 is a lower ratio than a 3.21 the 3.21 is the higher of the two.
A crown wheel and pinion could be anywhere between £120 and £240 depending on the type (std or LSD configuration) and ratio required second hand units are available but obviously have no history that you can make a decision on, you should always use a matched pair.
Don't bother trying to do the job with the power unit in the car as this is a skilled task that needs to be fitted correctly using shims etc.... you have to remove the radiator and end cover (speedo drive unit) and both drive shafts and diff side covers and the diff main cover..... however if you have studs holding the diff cover on you simply will not get it off.
Regards Martin
Posted 03 July 2009 - 10:20 PM
Posted 03 July 2009 - 10:57 PM
I'm not saying hold the stopwatch yourself as thats stupid but unless you got proper timing gear and the right conditons you not really helping yourself for figures?
Posted 04 July 2009 - 01:18 AM
very impressive cooperman, would love to do something like that but alas lack of funds prevents it. thanks for the spec tho i'm actually really pleased with how close it is to the cooper.
i recon that if i was gonna have to take the engine out to fit a 240 add-on id probs use the money plus a bit to buy a reasonable condition 1275, do it up n drop it in. thanks anyway for the price guide it's still very interesting to know these things.
oh and i know i shouldent have had a passenger but i at least made sure that the lightest one of them came in with me, it was only out of curiosity.
