Alternative Alloy Wheels
15 replies to this topic
#1 spikey
spikey
  • 97 posts
Posted 03 July 2009 - 02:40 PM
Does anyone know if its possible to fit some alloys not made for a Mini without major work? The ones I am looking are a 13" 4x100 VW fitment? I know that ATS Classics seem to be transferrable with wobbly bolts?
Many thanks
Mike
#2 bmcecosse
bmcecosse
  • 9,699 posts
Posted 03 July 2009 - 02:42 PM
NO NO NO ! Don't even think about it!! That's a NO then !!
#3 spikey
spikey
  • 97 posts
Posted 03 July 2009 - 02:46 PM
cheers :D
Is that a no because of pursit reasons or a no because it wont work :)
#4 m1tch
m1tch
  • 1,044 posts
Posted 03 July 2009 - 03:49 PM
Well that was straight to the point lol :D check out minisports, they have lots of different sorts and as they are for minis they are usually cheaper than if you did go for those different fitment rims :)
#5 Asphalt
Asphalt
  • 2,173 posts
Posted 03 July 2009 - 04:58 PM
Why?
#6 m1tch
m1tch
  • 1,044 posts
Posted 03 July 2009 - 05:12 PM
I think its cause its best not to use wobble bolts due to the fact that the 4 bolts are the only things holding the wheels on, best to make sure the wheels stay on the car and now put any extra strain on the studs?
#7 mini mark
mini mark
  • 876 posts
Posted 03 July 2009 - 05:14 PM
i remember in other threads that have been about this that the way the mini is set up it makes them unsafe to use im sure someone will tell you more.
Edited by mini mark, 03 July 2009 - 05:15 PM.
#8 Retro_10s
Retro_10s
    Moderator
  • 10,177 posts
Posted 03 July 2009 - 05:18 PM
This isn't a technical problem. So I've moved it to the styling section.
#9 Asphalt
Asphalt
  • 2,173 posts
Posted 03 July 2009 - 05:24 PM
Wobble nuts don't put any (extra) stress to the studs (that's what they'r designed and used for!).
http://www.serpentau...ion_lugnuts.jpg
Usualy they can make up a difference of up to 1.5mm radius. 100mm - 4" (Mini PCD) = 101.6mm = 1.6mm/2 = 0.8mm radius difference between VW & Mini PCD. That's not much.
BUT: IMO wobble nuts are useless without spigot rings or something else to centre the wheel! Without a centering system; I agree! Minis don't have a centering thing, it's just the wheelnuts centering them. So it's not a bolt-on job ( :D ) with a Mini, that's right. And of course it is NOT save to just bolt on 100mm PCD wheels with std. nuts & bolts!
http://www.theminifo...howtopic=128799
#10 chadd123
chadd123
  • 212 posts
  • Local Club: Wirral-minis
Posted 03 July 2009 - 07:33 PM
It all sounds a bit dodgy i would stick with mini wheels
Edited by Retro_10s, 03 July 2009 - 08:45 PM.
html edited out - doesn't work
#11 MRA
MRA
  • 7,607 posts
Posted 03 July 2009 - 09:31 PM
However if you really really want to fit non mini wheels then PM me as we can probably help you :proud:
Regards Martin
#12 Asphalt
Asphalt
  • 2,173 posts
Posted 03 July 2009 - 09:55 PM
That's of course the better option :proud:
And it's not that ATS never made 13" wheels with a 4" PCD :proud:
(But they are not wide & 'dished' & all recey - they'r just classic)
#13 MRA
MRA
  • 7,607 posts
Posted 04 July 2009 - 10:32 AM
And it's not that ATS never made 13" wheels with a 4" PCD ;D
I just love that "brick look" paintwork really authentic :proud:
#14 dave21478
dave21478
  • 639 posts
Posted 05 July 2009 - 08:36 AM
Wobble bolts are perfectly safe on other applications, but a minis lack of centre locaton means it is impossible to use them safely on a mini.
Hwever, there is no reason not to use a well designed set of PCD adaptors. These will act as spacers though, so watch your offsets.
#15 spikey
spikey
  • 97 posts
Posted 05 July 2009 - 10:32 AM
Cheers for the replies people... very helpful.
