Fuel Leak! Help Please!
26 replies to this topic
#1 skippersworld
skippersworld
  • 205 posts
  • Local Club: Not Yet
Posted 18 July 2009 - 04:58 PM
Noticed recently that my 1984 austin mini is leaking petrol, rather badly!! I've found where but no idea what it is lol!! Middle of the engine at the back just under some black plastic bit of the engine! A little bit of tube with plastic ends which push on to (at one end) a gold bit!?!?!? Sorry im rubbish with engines so i dont know what things are called! Not yet got a picture but will do soonish! But if anyone knows what this is and can help then THANK YOU =)
#2 jaydee
jaydee
  • 8,565 posts
Posted 18 July 2009 - 06:00 PM
Fuel overflow pipe?
Can you provide a pic of it?
#3 m1tch
m1tch
  • 1,044 posts
Posted 18 July 2009 - 06:04 PM
Sounds like thats the OEM location for fuel fuel line - plastic bit might be the air filter box, gold thing might be an inline fuel filter, probably best to post a photos.
I have moved my fuel line away from the very very hot exhaust manifold as this is how many fires in minis have started
Take a photo with the airbox taken off - the large round plastic box on the top - taken off with the 2 wing nuts, then you can see what the fuel line is like underneeth it
Edited by m1tch, 18 July 2009 - 06:05 PM.
#4 skippersworld
skippersworld
  • 205 posts
Posted 18 July 2009 - 06:16 PM
I can tell you whats wrong with the bit of pipe, where it pushes on the plastic bits either end have cracked and leaking a lot! Will try get a pic tonight of it! Its not a very long pipe, no longer than 20-30cm!!!!
#5 skippersworld
skippersworld
  • 205 posts
Posted 18 July 2009 - 07:46 PM
Here you go, pictures of the problem!! Helpppppp lol!
Attached File  P7180093.jpg   315.61K   6 downloads
Attached File  P7180094.jpg   326.71K   6 downloads
Attached File  P7180095.jpg   449.39K   7 downloads
#6 m1tch
m1tch
  • 1,044 posts
Posted 18 July 2009 - 07:50 PM
Where did that pipe come from in the engine bay? I didn't know there were hard pipes for fuel lol do you have AC in your mini?
#7 MiniBonkerz
MiniBonkerz
  • 1,893 posts
Posted 18 July 2009 - 07:52 PM
change the rubber
#8 skippersworld
skippersworld
  • 205 posts
Posted 18 July 2009 - 07:59 PM
AC stands for what? lol sorry if its a dumb question!
Like i said before its under the black plastic part in the middle back of the engine!
#9 skippersworld
skippersworld
  • 205 posts
Posted 18 July 2009 - 08:18 PM
Here you go, the rubber part goes onto the gold bit in this picture!!!
Attached File  P7180085.jpg   521.09K   8 downloads
#10 lrostoke
lrostoke
  • 6,923 posts
Posted 18 July 2009 - 08:20 PM
Its the fuel pipe from the fuel pump to the carb.
I'd go a local motor factors take the pipe with you and ask if they have any fuel pipe same size as the flexible ends, then just renew the ends.
The metal bits metal because of the heat off the exhaust :lol:
should be hose clips securing it as well
Edited by lrostoke, 18 July 2009 - 08:21 PM.
#11 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 18 July 2009 - 08:23 PM
You need to get hold of some replacement pipe, with matching internal diameter. Might as well change both ends while you have the metal pipe off.
Try halfords in the morning - take your original as a pattern. If its not urgent, perhaps a local motor factors will be cheaper, but doubt will be open sundays
#12 skippersworld
skippersworld
  • 205 posts
Posted 18 July 2009 - 08:59 PM
Brilliant!! Thanks for your help, nope not in a rush so thanks for comments people!! =D
#13 bmcecosse
bmcecosse
  • 9,699 posts
Posted 18 July 2009 - 09:01 PM
You could change the whole pipe to a braided type - but you would need to route it well away from the exhaust.
#14 skippersworld
skippersworld
  • 205 posts
Posted 18 July 2009 - 09:09 PM
Ok well ill look into both ways and just see whats best really!!
#15 jaydee
jaydee
  • 8,565 posts
Posted 18 July 2009 - 10:16 PM
A braided hose is way better than the steel one.
