Still Overflowing!
Posted 25 July 2009 - 06:43 PM
1. i think the overflowing has something to do with the fuel pressure being to high and the float cant stop it so maybe an inline fuel pressure regualtor could be used to decrease the fuel pressure???
2. the second solution is the one i thort of when the overflowing first started. it is to fit an MPI fuel tank and simply run a return pipe from where the carb is overflowing back to the tank. i am thinking that this will permanantly fix my problem and is the best way to go. what do you guys/girls think?
thanks.
Posted 25 July 2009 - 06:46 PM
Posted 25 July 2009 - 07:06 PM
Posted 25 July 2009 - 07:09 PM
It does sound as though the fuel pressue is too high, although a mechanical pump won't over-pressurise the fuel system.
Try a pair of small mole grips on the rubber fuel pipe to reduce the flow rate and see if this works and if the engine still runs OK. That will confirm the high fuel pressure theory (or not, as the case may be).
Posted 25 July 2009 - 07:24 PM
its not a blocked jet as i took the carb apart and was all good.
the mole grip on fuel pipe is a really good idea, ill try it and see what happens.
if it is the fuel pressure, will i be able to reduce the pressure via regualtor? or can that only turn it up?
thanksss
Posted 25 July 2009 - 07:29 PM
Posted 25 July 2009 - 07:42 PM
thanks everyone. ill let u know if things go up s**t creek again
Posted 25 July 2009 - 07:58 PM
help please thankyou.
Posted 25 July 2009 - 08:34 PM
Your old hs4 will be fine.
Whats the condition of the jet and the needle? Its the needle correctly fitted to the piston? Its the foat needle valve tightened well?
If you dont have a fuel filter, its not unusual that crap goes into the needle blocking it in a stick open position.
Another check you have to do:
Remove the float lid, hold it in one hand and whistle into the fuel inlet whilist with the other hand you start to push up slightly the float. You have to feel a little resistance as the float starts to push the float needle up, and a great resistance as the float has completely closed the needle.
Edited by jaydee, 25 July 2009 - 08:35 PM.
Posted 25 July 2009 - 08:51 PM
the jets clear but i dunno if i have the correct needle. how do i know which needle i have?
i have tried the blow and push on the float lid and always works fine but not when engines running. ive decided to get a filterking regulator.
then i will have to sort out the poor running.
Posted 25 July 2009 - 08:53 PM
Posted 25 July 2009 - 09:00 PM
Posted 25 July 2009 - 09:03 PM
hmmmm, yeah maybe ill change the carb tomorrow, the 44 was put on for experimantal purposes lol. and yeah im 100%sure the fuel is going in the right way. ive heard that the hs4 carbs are slightly restricting on the 998 engine.
Who said that? A tuned hs4 can give 1/2 more bhp compared to a twin hs2 setup.
Dont bother with the hif44.
Posted 25 July 2009 - 09:08 PM
you heard wrong, the hif 44 is way too big for a 998 unless you were running a turbo'd 998 anyways. the 998 runs very wel off of a hs4. if you wanted to go hif then the 38 is the way to go for the 998. the only difference being the intenal float chamber rather than the side chamber of the hs type.
