Hi everybody !
Does anyone knows at which temperature the standard Spi temperature sender engages the auxiliary cooling fan and then at which temp it disengages it ?
I ask you this because I've heard that the screw in sender sold with a 2 cores radiator is not the ideal one for a Spi Mini, so I need to know to choose a suitable sensor.
Thanks a lot.
Spi Fan Sender Operating Temperature.
Alexandre34
, Jul 26 2009 10:37 AM
3 replies to this topic
Posted 26 July 2009 - 10:37 AM
Posted 26 July 2009 - 10:44 AM
Hi everybody !
Thanks a lot.
Just get the standard radiator with the sensor.
Minispares one works just as good as rover ones and unless your racing there is no need for a fancy radiator.
mine kicks in just above half way on temp (1-2mm above the line) and cuts out just below
Edited by BGB, 26 July 2009 - 10:45 AM.
Posted 26 July 2009 - 01:56 PM
Hello,
According to the Heritage Manuals SPI supplement 1991-1996, the fan comes on at 98 deg C and goes off at 93 deg C.
Ivan
Ivan
Posted 26 July 2009 - 02:14 PM
Many thanks for your help and answers.
