Auto-manual conversion
Posted 20 September 2005 - 09:37 PM
Posted 20 September 2005 - 09:58 PM
Remove engine gearbox and subframe in one, if you prebuild a replacement subframe and suspension, then the only thing to do while it's all out is replace the pedal box, put in the clutch master and short the start inhibitor switch, then put the new subby/engine and gearbox in...
Could do the swap in 1/2 a day if you prepare...
Ohh... have a front subby, plenty of gearboxes and engines comming out of every orifice possible... can do a complete replacement unit of you want :cheese:
Edited by GuessWorks, 20 September 2005 - 10:00 PM.
Posted 20 September 2005 - 10:17 PM
I dont usualy sink to this level BUT ....Ohh... have a front subby, plenty of gearboxes and engines comming out of every orifice possible...
THAT HAS TO MAKE YOUR EYES WATER !
Posted 20 September 2005 - 10:21 PM
...the mind boggles!Ohh... have a front subby, plenty of gearboxes and engines comming out of every orifice possible...
Posted 20 September 2005 - 10:22 PM
the best way is to get a rusty complete running car as a donner, this conversion can then be carried out in a weekend easily
you will need a socket set and a set of combination spanners ,a good trolley jack and some axle stands (dont even need an engine crane)
the only awkward bit is the bleeding (if you havent done this before), oh and fitting the other pedal is a bit fiddley
Edited by Woody, 20 September 2005 - 10:27 PM.
Posted 20 September 2005 - 10:30 PM
Posted 21 September 2005 - 06:56 AM
Also make sure you have a few friends around for moving the body and engine/subframes around, you wouldn't want to drop one!
Posted 21 September 2005 - 07:19 AM
Posted 21 September 2005 - 07:23 AM
Posted 21 September 2005 - 09:31 AM
oh god I've got a headache now...
Posted 21 September 2005 - 09:43 AM
Posted 21 September 2005 - 09:46 AM
Posted 22 September 2005 - 10:27 PM
Back on topic... how (and forgive me if it seems like a daft question, but I AM an electrician!) does changing the subframe affect the steering gear? If at all... or does the old steering gear transfer over to the new subframe?
(And Guessworks... any idea how much you might charge for a built-up engine, gearbox and subby?)
Posted 22 September 2005 - 11:02 PM
Posted 22 September 2005 - 11:57 PM
