hheellpp
oli19
, Sep 22 2005 11:33 AM
8 replies to this topic
Posted 22 September 2005 - 11:33 AM
hi i have a 97 cooper and want 2 put 7x13 wheels on will they fit straght on??????????? and i want a wkd cloth induction kit ne1 no where i can get 1 frm???? wb plzzz oli 19
Posted 22 September 2005 - 12:01 PM
come on sum1 reply...........
Posted 22 September 2005 - 12:53 PM
What size wheels do you have at the moment?
Posted 22 September 2005 - 12:57 PM
lol ermmmmmmmmmmmmmmm????? round ones.
iam not sure will have 2 have a look but there small my cooper iant a sportspack
Posted 22 September 2005 - 01:03 PM
i think they are 12's matey, but i've only seen it when i drive past
Posted 22 September 2005 - 01:27 PM
I'm sure someone would if the could understand a bean of what you are saying...
Edited by GuessWorks, 22 September 2005 - 01:27 PM.
Posted 22 September 2005 - 02:33 PM
with you car being a 97' it will be running 12's so yuo will have to cut some metal away from your arches to fit 13's..... probally best to change out wheel bearings as well as they put alot of pressure on them.
Al
Al
Posted 22 September 2005 - 02:37 PM
Or you can get steering rack limiters from KAD, however I don't know if this will stop the wheel hitting the inner arch as 7" is about as wide as you can go on a road car. You may need to cut some metal away from the outer arch as well.
ww.kad-uk.co.uk
ww.kad-uk.co.uk
Posted 22 September 2005 - 05:18 PM
You'll need to trim the front arches if you want to fit 7" x 13" arches. When you turn corners the wheels will rub otherwise. You'll also need new arches to cover the rims to make it nice and legal. I have a set of 7 x 13's on mine (a standard mini shell) and it'll need a few inches of the front edge of the front arches trimming out.
As standard it'll be on 12's if it aint a Sportspack I'd guess.
As for the filter, try minispares or something. You can buy ones that go in the original filter box, or ones that replace the air filter box. Depends on what you require from it and your budget. :grin:
And I think the KAD rack limiters will work (prevent inner arch rubbing), you can get the collars from various places. Or you can fit a Sportspack rack. Some people do have standard racks and their wheels don't hit the inner arch (which is weird)!
