anyone had a problem with chargee rate on a hayabusa mini
Charging System On Busa Mini
doncaster aut trimmers
, Aug 05 2009 07:23 PM
2 replies to this topic
Posted 05 August 2009 - 07:23 PM
Posted 15 August 2009 - 06:56 PM
What problem do you have with your charging system?
I had some problems too, but must were caused by too thin wires for the high amps going through...
This is the best thing to check first before swapping parts. I have replaced the Rectifier, generator and stator and all was officially caused by wire-choice mistakes in the first place.
Posted 20 August 2009 - 09:39 PM
had a problem it was the solenoid 2 main wires were wrong way around causing it to blow the rectifier,hope this helpsanyone had a problem with chargee rate on a hayabusa mini
