Detuned Spi
Posted 06 August 2009 - 07:37 PM
I have a '96 Mini Sprite SPi, and reading around the topic it appears that the Sprite is detuned to 50bhp versus 60bhp+ for the Cooper models. I was wondering if anyone here knew how this was achieved - I suspect it's just in software on the ECU, but don't really know. If it is just the ECU, does anyone know if a Cooper ECU can be installed to recover the extra power?
Also, my exhaust is in a sad state and rather than just replace it from the cat back I'm thinking about getting a Minispares Stage One kit - does this actually give any noticeable increase in power?
Regards,
Dave
Posted 06 August 2009 - 08:31 PM
Posted 06 August 2009 - 08:56 PM
a stage 1 kit would be worthwhile. with regards to the detuned bit, im not entirely sure how it was 'detuned' compared to the cooper, it may be more than just ecu mapping.
I'm sure I was told there were differences in the head, bigger valves maybe? Could be bol*ocks of course...
Posted 06 August 2009 - 09:00 PM
Posted 07 August 2009 - 01:09 AM
Posted 07 August 2009 - 08:20 AM
Hope this helps
Rob
Posted 07 August 2009 - 09:38 AM
Thanks for the replies - I should have know it wouldn't be anything easy to deal with!
Thanks,
Dave
Posted 07 August 2009 - 02:12 PM
There are several versions of the ECU which can be broken down into two catagories, one plug and two plug. The two plug ECUs were only used on the early cooper. The one plug ECU, there are several versions used on both cooper and non cooper, some are coded for use with a coded factory fit alarm/ imobiliser and some are uncoded.
Changing just the ECU on a non cooper engine without any other modification will do nothing except maybe iterfere with the tune of the engine.
Posted 07 August 2009 - 02:16 PM
Posted 08 August 2009 - 07:07 PM
like mine, from 1992
Posted 11 August 2009 - 10:56 AM
Posted 11 August 2009 - 11:40 AM
However incorrect it is..
By the same token my scoobie must be a de-tuned WRX rally imprezza
Posted 11 August 2009 - 12:32 PM
I love the terminology "Detuned SPi Engine"
Yer thats why i wrote
'detuned' spi
Posted 11 August 2009 - 06:09 PM
Keep in mind the 'detuned' spi pistons have a different dish.
No they dont
The difference in compression ratio from the cooper to the non cooper is achieved with a different compression hight of the piston, not the dish, the dish is exactly the same, the lower compression piston is shorter
