1998 MPI rebuilt with MED stage 3 head
swi05 cam timed to 107 degrees
1.5 rollers
52mm throttle body
KN induction kit
Maniflow LCB
Gas flowed maniflod (opened out slightly)
Fuel pressure regulator
New plugs etc
So basically from the first time i took it for a drive ive been having this same issue. At over 3000rpm is splutters and does not have any more power.
It feels like it is running lean hence i fitted the pressure regulator, but no difference.(set at 38psi) Nick from here has helped me with a few settings, but still no difference (thanx Nick)
In 1st gear, just over 3000rpm, its spluttering, in 2nd the same, in 3rd i have no power from really low down and 4th is the same.
Car idles fine and everything seems normal. Ive had it run through a computer (not running at the time) and everything came back ok.
One thing i noticed this morning, my oil temp clock. From i fitted the clock it has never moved over 50.In fact it has never moved at all.
So i disconnected the plug from the sensor and stuck a tester in there and it glows up but only very dim (ive no volt meter yet)
I highly doubt it but would this be a problem and could it be linked to my bad running??
Does the ECU need oil temp to control fueling? Or maybe this sensor only needs a small amount of power as it is only reading.
I have been told the SW5i might be the problem and the timing maybe out?? (heard stories you need to set this cam by trial and error)
Im getting to the stage now where im just p*ssed of beyond belief. I have 1 more show this season i want to make but at this rate im not sure.
Really any help would be seriously appreciated. Can you see im desperate!!
Edited by tony kenobi, 09 August 2009 - 12:58 PM.
