What Year Did The Change From A To A+ Happen
Posted 11 August 2009 - 03:08 PM
i need to know as i have a 1980 engine with no stiffening ribs on that i thought was an a series but when i tried to order a new gearbox the bloke swore blind that that year is a a+ engine
Posted 11 August 2009 - 03:34 PM
Posted 11 August 2009 - 03:38 PM
The A-Plus version of the 998 cm³ motor was produced from 1980 until 1992.
Applications:
* 1980–1982 Mini 1000/City/HL, 39 hp (29 kW) at 4750 rpm and 52 lbf·ft (71 N·m) at 2000 rpm
* 1980–1982 Austin Allegro, 44 hp (33 kW) at 5250 rpm and 52 lbf·ft (71 N·m) at 3000 rpm
* 1980–1990 Austin Metro, 41 hp (31 kW) at 5400 rpm and 51 lbf·ft (69 N·m) at 2700 rpm
* 1982–1988 Mini HLE/City E/Mayfair, 40 hp (30 kW) at 5000 rpm and 50 lbf·ft (68 N·m) at 2500 rpm
* 1981-1986 Austin Metro HLE 46 bhp (34 kW) and 52 lb·ft (71 N·m)
* 1988–1992 Mini City/Mayfair, 42 hp (31 kW) at 5250 rpm and 58 lbf·ft (79 N·m) at 2600 rpm
Posted 11 August 2009 - 03:43 PM
They only difference that matters for an engine swap is the transfer gears.
A+ transfer housings have 3 bolt holes for a Metro engine mounting on the back.
Posted 11 August 2009 - 03:45 PM
Posted 11 August 2009 - 03:53 PM
850's never went in Metros so no reason for them to produce any A+ ones
As I said, your best clue is the Metty bolt bolt holes.
Posted 11 August 2009 - 03:54 PM
Just checked parts catalog, a big clue is the dizzy drive and that was only ever referenced as the A series version on the 850, so I'm 99% sure the 850 was only ever produced in A series form, and even checking Metro parts this also reference only the A series dizzy drive for the 850 metro.
Edited by GuessWorks.co.uk, 11 August 2009 - 03:58 PM.
Posted 11 August 2009 - 03:55 PM
also im a novice so whats a transfer housing is that the bit on the back of the box where the rods go into
Edited by feybrand, 11 August 2009 - 03:57 PM.
Posted 11 August 2009 - 04:03 PM
Edited by GuessWorks.co.uk, 11 August 2009 - 04:03 PM.
Posted 11 August 2009 - 04:05 PM
Posted 11 August 2009 - 04:06 PM
i havent got a metro and the engines out of a mini so how do i work out for definate what ive got
Have you got the engine number? I think Guessworks has a page where you can decipher the number
Posted 11 August 2009 - 04:08 PM
