Master cylinder removal - any tips?
19 replies to this topic
#16 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 13 August 2018 - 11:13 AM
Its just persistence with different spanners at different angles, might be one flat at a time flipping the spanner over each time
or snapon shallow 1/4 drive socket / ratchet, don't think you can get from above even with a uni joint and wobble end extensions
#17 DeadSquare
DeadSquare
  • 3,177 posts
Posted 13 August 2018 - 11:56 AM
That is a bit tight.
Assuming that your Mini uses imperial nuts and bolts:-
Get hold of something like a scrap of thinish 9 inch square plywood.
Drill a 5/16" hole in a corner and do up a 5/16" nut and bolt through it.
Place your ring spanner on the nut and draw either side of the spanner.
Move the spanner round 1/12th and draw again.
Rummage through your friends tool boxes or go to hardware stores and find a spanner that fits on the nut, half way between the two drawings.  Better still, you might find two spanners that fits a third from either drawing.
Two (or three) slightly different spanners should enable you to rotate the nut in that confined space.
Pull a bit of string back and forth in the threads above the nut to remove crudd, and when loose, it might be only finger tight.
#18 Spider
  • 15,079 posts
Posted 13 August 2018 - 07:35 PM
I can usually do them with a 1/4 drive socket and long extension, though I find I have to maneuver the socket itself in place from the side and then lower the extension bar in from the top.
#19 nicklouse
  • 18,679 posts
Posted 13 August 2018 - 07:39 PM
i have a spanner the right shape for this. a vice and a big hammer made it.
#20 imack
imack
  • 2,195 posts
Posted 13 August 2018 - 08:15 PM
Ah yes, I also have a special master cylinder spanner
