Crank Hitting Gearbox Casing
Posted 19 August 2009 - 08:55 PM
Just did a dry fit of A+ engine (MED1380) to an A gearbox and number one journal is hitting the casing. I know that this is a problem with early casings but:-
Question is how much do you need to grind away and number 4 is obviously the same, the case already has some marks by number 4 in it where a previous journal has rubbed. Does 2 & 3 give problems also.
If anyone has a picture of the grind would be appreciated to show exact location to work on as I want to get the engine in ASAP missing driving the mini so much especially with a nice new MED 1380 Type R..........
thanks Rofert
Posted 20 August 2009 - 08:05 AM
Posted 20 August 2009 - 08:27 AM
However, to get round your issue the only option is really a trial and error approach... I assume it's the leading edge which is contacting the gearbox at the front of the case.
This may not be much help but what I would do is gut the box, dry fit the block onto the box with no gaskets and see where it hits and start grinding away with either a die grinder or dremmel until you have clearance. Dry fitting without the gaskets means when they are added you'll have a few extra thou' of clearance.
Posted 20 August 2009 - 11:34 AM
Edited by haz, 20 August 2009 - 11:34 AM.
Posted 20 August 2009 - 01:05 PM
Haz not sure what rods they are as it was all supplied and put together as a short motor by MED, will have a look at the casting numbers tonight. How did you overcome your clearance issues?
Rofert
Posted 20 August 2009 - 06:36 PM
Anyone else got experience if this?
Rofert
Posted 24 August 2009 - 07:26 PM
Gear box and engine now mated together, onto my next question?
I need to get a new priamary gear straight cut for 1275 crank and to match the intermediate and 1st motion gears, am I correct in thinking that I will need to fit a A primary not A+ as the gearbox has A gears?
Also does anyone have a 23 tooth straight cut A primanry gear to sell.
Rofert
Posted 25 August 2009 - 12:48 PM
The only thing I will say, and from experience, is that straight cut drop gears for a road car are horrendously noisy and not really necessary.
Posted 25 August 2009 - 01:03 PM
There are differnces in the Idler gear beteween A & A+
Posted 25 August 2009 - 02:57 PM
Posted 25 August 2009 - 09:53 PM
Found a set of helical ones in the garage tonight which used to be in a 1295 (short stroke) engine that was fitted to my rally GTM Coupe, I changed them to straight cuts and never had any problems with them it just used to eat through it's bing end bearings.....I did rev it to about 8.5-9k though so that may have something to do with it.
I have early casing and want to retain it as it matches the age of the car, so will need to buy a set for an A series box which are available just got to get the pennies together.
Rofert.
Posted 25 August 2009 - 10:02 PM
Posted 25 August 2009 - 10:10 PM
Anyway, I took the engine off the box, marked the sides of the box with 'engineer's blue' and used a rotary burr to remove metal. Once I got clearance at all points, I took about another 0.015" off the areas of minimal clearance and it all worked fine. I've not tried an A+ on a later Cooper 4-syncro non A+ box, but it should be OK. I'll find out soon as I have a Clubman GT engine to do with A+ rods going onto an A 4-sync box.
Posted 26 August 2009 - 12:27 PM
All seems OK hand turning just lots of fingers crossed for the first time at 7K
Rofert
