Gearbox Grinding
24 replies to this topic
#16 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 26 August 2009 - 10:52 AM
It'll be a worn Baulk Ring on the 2nd to 3rd Syncromesh, THE most common problem on a mini gearbox.
#17 jaydee
jaydee
  • 8,565 posts
Posted 26 August 2009 - 10:55 AM
Exactly, and right now i noticed it is an MPI mini, so it uses cheese baulkrings.lol
#18 liirge
liirge
  • 4,097 posts
Posted 26 August 2009 - 10:57 AM
If it was the clutch you would have similar problems on ALL gears. Liek Jaydee said the MPI baulk rings where not known for their strength. For gearbox rebuild and inspection PM Guessworks on here
#19 monkeymonk
monkeymonk
  • 367 posts
Posted 26 August 2009 - 11:52 AM
Guessworks is a tad far away for a gearbox inspection. Route planner says its 3 hours away >_<
#20 tog77
tog77
  • 161 posts
  • Local Club: maun mini's
Posted 26 August 2009 - 09:46 PM
i can do it for you if you want to get it to me(nottinghamshire)..i'm an ex (retired) gearbox specialist...
tog77....
#21 monkeymonk
monkeymonk
  • 367 posts
Posted 26 August 2009 - 10:02 PM
tog77....
tad far away :D but thanks anyway
#22 tog77
tog77
  • 161 posts
Posted 26 August 2009 - 10:48 PM
i could do it for you if you got it to me(notts)i am a retired gearbox expert..did have my own business..........
tog77
#23 tog77
tog77
  • 161 posts
Posted 26 August 2009 - 10:52 PM
sorry about that..did not see your answer..it looks like worn syncro rings and have the rear double mainshaft bearing changed while its down...
lots of luck...tog77.....
#24 icklemini
icklemini
  • 2,982 posts
Posted 26 August 2009 - 10:58 PM
There is a gearbox expert on this forum
LOL only one eh??
The best place to get it done, would be if you can find an old school mechanic. You know the ones, they've done cars for a living all their 50+ life, drink a bit to much tea and are normally self employed renting garage space...
Sounds familier...
#25 bmcecosse
bmcecosse
  • 9,699 posts
Posted 26 August 2009 - 11:09 PM
It won't be worn 'syncro rings' - well they will now be worn - but the REAL damage will be to the dog-teeth on second gear which will need renewing!
