Hi all
having abit of trouble with my indicators, none of them are working
the fuse in the fuse box blew for no reason and I have replaced it but still nothing, in the haynes manual it has the fuse box fuse and a seperate line fuse but I can't find this anywhere in the car to replace it
if any one know the location of it please let ke know as this is the only thing I haven't tryed
cheers all
Indicator Problems On An Spi
ShoppingTub
, Aug 27 2009 08:34 PM
1 reply to this topic
Posted 27 August 2009 - 08:34 PM
Posted 30 August 2009 - 03:32 PM
hi i had the same problem!! i found the fuse behind the air filter box peel the foam along the bulk head back and they should be behind the foam. there white in line fuse holders it was a blue/red wire on my 1996 spi 15amp fuse hope this helps let me no how you get on
