Starting Problems
5 replies to this topic
#1 Joloke08
Joloke08
    Not banned but still weird
  • 828 posts
Posted 29 August 2009 - 09:08 AM
!995 Rover Mini Sprite Automatic 1275 Single Point Injection
Can Anybody help?
We sent Boris away to have a gearbox with no starting problems whatsoever no he wont start :cry
His Fuel Pump primes as you can hear it and pump fuel up front ;)
Starter Motor is functioning properly :( :D
Battery is fully charged an nearly new so not a problem :-
Once the car is started it will happily start all day long but let the engine go cold over night and it refuses to start however it will once its had its fix of its "Crack Cocaine" also know as "Easy Start" down the air intake :genius:
If it starts and runs after that whats in the stuff and im hoping theres a clue in there as to why it wont start?
Something enables it to start when Easy Start is used so what is the Easy Start Mimiking that the starting system isnt doing but should be?
Huggz
Jodie ^_^
#2 minimat
minimat
  • 690 posts
  • Local Club: anglian mini club
Posted 29 August 2009 - 11:57 AM
Maybe they left the coolent temp sensor disconnected as it is hidden away and easily forgotten,does the gauge work?
#3 Joloke08
Joloke08
  • 828 posts
Posted 29 August 2009 - 12:17 PM
Thanks Matt
actually no the gauge isnt working but it was before it went away ;)
Where is the coolent temp sensor? i know the one for the electric Fan at the base of the Rad wasnt connected but thats been reconnected now im just hoping its another one your talking about and it is that causing the starting problems?
Huggz
Jodie :(
#4 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 29 August 2009 - 10:24 PM
the coolant temp sensor is underneath the inlet manifold, on the right side as you look at the engine. Its close to the bulkhead, and you will need childs hands to get in there without disconnecting something.
Check to see if it is infact connected. The wires run from the same area as the stepper motor wich is also on the right side of the inlet manifold, where the throttle linkage is. there will also be a single fairly thick wire with a spade connector, which should also be connected to the underside of the inlet manifold to the PTC heater element. Use a mirror to see if they are connected or not. If they are connected, its possable that the sensor is faulty. It could also be faulty wiring as I have known people to remove SPi engines with the manifolds still in place and end up tugging the wiring loom as they were unaware that it was still attached to the inlet manifold. Others I have heard of where the wiring had been trappped when the engine went back in.
#5 Joloke08
Joloke08
  • 828 posts
Posted 31 August 2009 - 11:32 AM
Thanks Guys
im going to look into this it is looking like that is the problem,a slight whiff of Easy Start and its Off ;)
Also Once warm starts First Time Everytime :)
Ill Check if it is indeed Connected if not thats the problem if it is ill change the sensor hopefully that will Fix it >_<
Huggz
Jodie :D
#6 Joloke08
Joloke08
  • 828 posts
Posted 02 September 2009 - 08:03 AM
Hes Fixed!!!!! :P
Rather Than Go repeat everything Check out my thread
http://www.theminifo...p;#entry1569887
Sprocket you were spot on :geek:
wasnt Even Connected,Was when we took it to have the gearbox done come back not connected :thumbsup:
Make of that what you will ;)
Thanks Guyz
boris Starts First Time Every Time Now :thumbsup:
Huggz
Jodie :thumbsup:
