We bought Moocher the mini (1992 reg, 1000cc) a year ago from a friend of a friend, who had left it rusting on a driveway without being driven for a year and a half. We gave her 350 for it and then had to spend 650 pounds getting it through the MOT - the sills had rusted away and were replaced and welded (badly I have been told).
Since then I have spent probably 300 pounds on her or so, parts and tools and the engine brace wasn't secure or something and needed to be fixed. I have been told that the rear subrframe is corroded and also that the car is "sitting on the bumpstops" and has no suspension - the garage I took it to refused to test drive it for this reason. I assume the suspension was removed to "lower" the car a while ago, but it has never failed an MOT for that reason. It is so bumpy that my wife stopped being able to travel in it when she was just a few months pregnant!
There is rust on the bonnet, a dent on the front right of the car (not too major) a lot of rust below the boot where she was reversed into a lampost a few years ago, and some of the paintwork is bubbling. Boot panel is black replacement while the rest of the mini is blue. Lock on boot doesn't work.
The heater leaks, but due to the use of a lot of sealant only very minor amounts(a rag collects most of the coolant), but when the heater is on you can smell coolant strongly.
The two back tyres need replacing (slow punctures), and the gear stick jumps around a lot - it sometimes hits me on the leg and it hurts!
What do you think?
