The engine sounds lovely until 3500rpm when there is a very pronounced knock coming from what sounds like the left hand side of the bottom end, near the clutch end.
The oil level was just above minimum - I've topped it up to full. The oil seemed free of any metal particles, so it doesn't look catastrophic!
After I do my few little checks (which I'm fairly certain won't give me the good news I'm hoping for) I plan to get the engine out, split it and check the condition of the shells and crank and replace accordingly.
I've read that it's possible to take the engine out, leaving the gearbox in the car, and since I'll need the box off to access the crank, This way might save me a little effort? What do you reckon? I'll be buying a haynes manual for the torques etc, but is there anything else that is better?
In a weird way, I'm actually looking forward to having a good tinker with it!
I think what happened is the engine was running very hot all the way home - The car has a digital dash which said 88-94 degrees all the way back, but the sender for this is in the top of the radiator, and I don't think it was actually in the water!
There is an analogue temp guage, which runs off the normal sender. This guage was right at max all the way back, I'd assumed this was just down to an inaccurate guage, as it read this even when the digital guage said 86c.
Since the engine was running this hot with no oil cooler, the oil got overhot and thinned down too much causing my problems.
Edited by cobblers, 09 September 2009 - 08:54 AM.
