I've recently had a new downpipe fitted for the Mini to pass it's MOT, and ever since, it's had a very noticable flat spot between about 3800 and 4000 rpm. When it hits 3.8k, there is a small but obvious decrease in power, and the power then comes back again at 4k.
To fit the downpipe, it was necessary for the manifold and air intake/throttle body to be removed in order to get a broken stud out of the manifold.
Also, the car has been idling rather high (about 1500rpm) on start-up for about 5 minutes, at which point it settles down a bit. Again, this has only happened since the downpipe has been replaced.
Any ideas on why this might be?
Flat Spot Just Under 4000 Rpm, & Fast Idling
Jet Williams
, Sep 09 2009 02:25 PM
No replies to this topic
