Hello and help
4 replies to this topic
#1 shabbak
shabbak
    Starting My Mini Up
  • 1 posts
Posted 29 September 2005 - 11:43 PM
Hi Everyone
My friend bought a beautiful 91 Mini Cooper recently. All went well until a broken engine mount caused a hydraulic pipe from the clutch to break. He took it to a local garage and the guy fixed the broken engine mount, the one in front of and closest to the driver, and the hydraulic pipe. He was able to drive the car for about 3 miles then it died. From then the car will start and sounds sweet until it reaches 90 degrees. Then it will die when you touch the accelerator. The guy in the garage has checked everything he can think would cause this problem IE fuel filters, pump, fuses, etc.
Can anyone advise????
I would really appreciate some guidance.
Steve
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 30 September 2005 - 08:34 AM
there is a earth strap near that engine mount :smartass: have a look and make sure its still there :cry:
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 30 September 2005 - 09:15 AM
Is it carb or SPI ? not sure when the voodoo took over ?
#4 chunkomunko
chunkomunko
  • 350 posts
Posted 30 September 2005 - 10:59 AM
no good at tech stuff but welcome :cry:
#5 CharlieBrown
CharlieBrown
  • 6,587 posts
Posted 30 September 2005 - 12:43 PM
Welcome to the site.
Could you post a picture of your mini? (Not for tehnical reason you understand just to see it :cry:)
