hi my mini rad is leaking from the sensor that workes the electric fan!! i took sensor out and seal looks ok but on the seal it says DO NOT REUSE as i did not have one i cleaned it and put it back since then the leak is bad can any one tell me can i put sealer around it as i cant find this seal any where!!
Coolant Leak
cbyrne
, Sep 11 2009 07:52 AM
3 replies to this topic
Posted 11 September 2009 - 07:52 AM
Posted 11 September 2009 - 10:46 AM
Why not just order a new seal? chuck some sealant/hylomar around it untill you get a new one.
Edited by dickster, 11 September 2009 - 10:48 AM.
Posted 11 September 2009 - 11:37 AM
These sensor seals are renowned for leaking, the design is rather poor. One solution I have found to improve the situation is to make several cardboard washers from a ceral packet to sit between the sensor and the purlple clip which holds it in place to make the seal slightly tighter. A more expensive alternative is to get a new 2 core rad from minispares with the screw in type sensor.
Posted 15 September 2009 - 11:35 AM
got sortded mini spares is a god send:)
