Sensors Eg Lamba
Posted 11 September 2009 - 09:37 PM
Posted 12 September 2009 - 05:55 PM
I dont see how changing the sensors with ones from a different car is going to get you more power, all theyre going to do is either tell the ecu the same thing that the original sensors would do, or not work properly and cause you issues. I would be inclined to work on the inlet manifold, cylinder head and exhaust system, as thats guaranteed to give you a noticeable gain in power and torque. A good set of plugs and leads (even just new standard stuff) will help out too.
Posted 12 September 2009 - 10:41 PM
Not on a mini there isnt...There will also be a mass airflow sensor, that detects the amount of air and speed at which it enters the engine.
Posted 13 September 2009 - 02:22 PM
ive learnt something else
Posted 14 September 2009 - 07:43 AM
hi i have been thinking yet again about more torque for my mini:D ok il try explain this the lamba sensor workes at low revs and tipping around eg (1000-2500rpm) where as the map sensor takes over at full throttle (1000-6500rpm) so my theory is uprate map sensor from a rover 400 spi along with injectors bore out inlet manifold, polish throttle body, lcb along with a good set of leads and plugs will this over power the ecu or can my theory work?? any answers welcome
Both the lambda sensor reading and manifold pressue effect fueling throughout the entire engine load/rev range. Changing the MAP sensor will have no effect whatsoever, the manifold pressure will still be the same. Either way, the sensor is built into the ECU anyway so you can't change it. A good service, improved air filter and LCB/exhaust system are a good start.
There is no airflow sensor, there is however an inlet air temp sensor in the air filter housing which is used to calculate the density of air entering the engine and adjust fueling accordingly.
