Turned down the fuel pressure a half turn and took it a drive, it was clearly short on fuel so I put it back a quarter turn. Felt fine on the next test drive, as far a fueling goes, but still had the same old problems at the same revs (about 2000 and about 3000)
The vacuum hose coming from the brake servo is bent at a bit of a sharp angle. It's not closed, or even anywhere near it, but it's not the way I'd want it. I can't sort it because the pipe above it that's squashing it down is dripping fuel as soon as I loosen the clip.
I could find no other squashed pipes, or even melted or split pipes.
If you look at the photo below, I did find a pipe connected to nothing! The green end was tucked away in below the reservoir.
IMG128__Medium_.JPG 264.08K
30 downloads
Cleaned the coil and ecu connections - all seemed ok here.
All coil connections are fine and in the right order, as are plugs/sparks and leads.
Cal me a dumpling, but I couldn't find the cam sensor! According to my haynes, it's at the back of the cylinder head and visible when the air filter's taken off - couldn't see it! OK with finding the inlet temp sens, lambda, map - but couldn't see the cam sens at all.
When I was in, I decided to put my pipercross filter back on - love the noise! Had to do something productive!
Anyway, after all that, I took it one more drive and it's still generally wonky.
