you can do a nice install...if you got the following as well!...
Tools: a jigsaw cutter, decent screwdrivers, hand drill (+ 3mm pilot bits), multi-meter
Materials: woodglue, 2" wood screws, 2 core cable (you can get away with mains cable on the cheap, but OFC would be better looking!), another amp wiring kit (if not 12 or better guage power cable) single core cable (for remote on), 2x 3+ metre RCA cable, twin fuse holder
There's quite a lot you can do with your kit...
run 2 pairs of speakers from HU, a pair of speakers (higher power) from kenwood amp running hi-pass (~50hz+), full range & 6x9's off the alpine doing (a bit) of bass.
run 1 pair of speakers from HU, 2 pair of speakers (if 4 channel or 2 channel allowing 2ohm) from Kenwood, again 6x9's off alpine.
If you've got plenty of MDF (jammy bugger) you could make your own styled door panels with speaker pods/inserts to suit. a lot of mini owners put 6x9's under the rear seat to achieve space saving bass, again MDF to the rescue! create a 'stealth' shelf on the back to fit any of the speakers (you may need to cut through the metal work to recess the speakers). make a boom box for the boot and fit 2x 6x9's in it running in mono
when it comes to wiring the amps, you can either wire them independantly and have 2 fuses, 2 positive cables etc. or have a main cable from the battery going into a 2 fuse holder, a 30A fuse should be enough for the Alpine (30Ax14v=420W max), you'll have to work out the fuse for the other amp (you didn't give any details!) and wire to each amp. run earth cables from amps to the nearest ground point (i usually look for a fixing bolt in the chassis! ...clean well until shiny, rust-free metal)
Take you single core wire from the back of the HU to the remote of the amp (normally this is designed to operate 1 device, you may get away with 2 amps) and then from this amp take the cable to the remote of the last amp. any more than 2 amps, then i would recommend using a powered relay.
Take your 2 pairs of RCA's from HU to the amps, 'sub' out to the alpine and 'front' or 'rear' to the kenwood (i tend to use the 'rear' but that's a personal choice)
before fitting speakers, measure them with a multi-meter (at lowest resistance setting) normally these should read around 4ohms (+-1ohm) there are different speakers and resistances but that shouldn't be a concern with your kit. when you've wired your amps etc. measure the resistance from car battery terminal to amplifier terminal this should be as close to 0ohm's as possible (ideally less than 1ohm) do this on both + and -.
sorry if all this is old news...it just came across as you are new to ICE
