on finishing welding the heelboard and fitting my 2nd hand subframe, i came to fit one side together radius arm suspension cone and so on, all fine.
but when i came to fit the other side radius arm on, it seems the arm wont go far enough in towards the middle so i can get the four bolts in which hold the plate on he outside? is the subframe bent or is it likely to be a prob with the arm itself?
Radius Arm Fitting
79mini1000
, Sep 22 2009 09:38 PM
No replies to this topic
