Right thsi first, Clicky , was for both subs, - I know you said to treat each speaker seperatly but i think this may work?
Each sub = 500w so im looking for a 400 -> 450w amp. The one ^ up there ^ is 400w on each channel - so heres the bit i got confused with, could i run each sub off one channel and then this;
Headunit to power the two 5 1/4" up front. Only thing is its putting out 45wx4. Is there some sort of resistor i can put in the line or will it be ok as is?
Thanks.
PS I know this is now a 3 page thread now, just wanted to say i appreciate the help and all the questions and quite probably all the hair you've pulled out when im to thick to understand!
amp, good choice. looks good on paper
the head unit will really only be about 4x13w or there abouts.................
what you could do is...............
stick a pair of 6.4Mh coils on each sub, a pair of 200mf caps on the components and run the lot from the one amp
basically you will have a 3 way filter which will keep the ohmage like the graph above..... a very basic 3 way passive crossover
no worries about the questions we all had to start somewhere its good now to be able to pass it on to someone who listens
Cool, I take it it would work then, just that the other way means more dough Me being cheap i guess
Only other thing left is the power cables. Any ones work or do they range in Ohm Volts etc...?
