-how are they better than the conventional gearboxes?
-what are the advantages?
i know there have may been some light on this topic before but i would like to know you opinions..
cheers
Edited by Joycey, 02 October 2009 - 01:25 PM.
Posted 02 October 2009 - 01:23 PM
Posted 02 October 2009 - 01:48 PM
Posted 02 October 2009 - 04:02 PM
Posted 02 October 2009 - 04:23 PM
Edited by Minigirl, 02 October 2009 - 04:24 PM.
Posted 02 October 2009 - 04:53 PM
Posted 02 October 2009 - 04:55 PM
Posted 02 October 2009 - 04:56 PM
Posted 02 October 2009 - 05:05 PM
Posted 02 October 2009 - 05:59 PM
Posted 02 October 2009 - 06:44 PM
not correct, dog box's as they do away with syncro allows space to use wider gears inside...if they did double helicle would be all together better
Edited by Dan, 02 October 2009 - 06:44 PM.
Posted 02 October 2009 - 06:58 PM
Edited by Lot, 02 October 2009 - 06:59 PM.
Posted 02 October 2009 - 07:20 PM
Posted 02 October 2009 - 09:10 PM
Posted 03 October 2009 - 01:10 AM
Edited by TimmyG, 03 October 2009 - 01:18 AM.
Posted 03 October 2009 - 01:30 AM
I think you meant to say that SC GEARS arent stronger than helical gears, as you say a helical gear has a larger tooth root to spread the load and is therefore stronger for a given material. However a gearBOX built with straight cut gears will be stronger i.e.more durable as the bearings are no longer having to cope with thrust loads.SC boxes arent stronger than helical. A helical gear has a longer 'root' therefore are stronger than SC, but you still are quite unlikely to break one
Paul
