Sc Drop Gears
Posted 14 October 2009 - 09:44 PM
i want to put S/C drops in my 1275
what do i need from mini spares for this conversion
do they do a 1.1 ratio same as standard
Posted 14 October 2009 - 10:03 PM
Jack Knight did 1:1 and 1:1.04, these used the same bottom gears allowing the overall FD to be altered slightly by changing the primary gear. They also did a 1:1.08 set but these have to be run as a set.Hey all
If you are running a road car, I wouldn't bother unless giving up on in car conversation.
Posted 14 October 2009 - 10:05 PM
do mini spares do a kit
Posted 15 October 2009 - 06:35 AM
PS, it's not an in car change without the use of special tools, so it's likely you're pulling the engine.
Posted 15 October 2009 - 08:05 AM
what do i need
primary + input gear and transfer
what will the different teeth do on the gears
Posted 15 October 2009 - 09:38 AM
Posted 15 October 2009 - 09:42 AM
The idler is a common gear, so is shared for all drop ratios...
The Primaries are available with different tooth counts, as are the input gears..
Usually, 22, 23 or 24 teeth and even some 25's..
Changing which tooth count primary you use with which tooth count input changes the ratio, the idler does not affect the ratio.
The 'best choice' is when considering 1:1, is to run 2 23 tooth gears ( Primary and input ), ie the middle ratio...
And yes, it's the drop gears which produce the whine, more so than the gearbox.
Posted 15 October 2009 - 12:02 PM
Ear plugs?
Posted 15 October 2009 - 09:13 PM
Ear plugs?
Yes, oh Yes!
I fitted SC drops a couple of years ago when my helical transfer gear finally packed up after 30 rallies.
The SC gears are so noisy I am going to revert to helical ones as I need ear plugs even for short road journeys.
It's fine with crash helmets on, but on the road it's 'orrible'.
The SC CR box is bad enough, but never, ever again SC drop gears.
Posted 15 October 2009 - 09:28 PM
Ear plugs?
Yes, oh Yes!
thats over reacting, i drove mine through 600 miles newquay and back, but hey i might have less sensative ears than some
Posted 15 October 2009 - 10:41 PM
engine has got to come out the diff needs a rebuild
Posted 15 October 2009 - 10:50 PM
The MSC/EVO (original and genuine Trannex desugn) drop gears are manufactured using more exacting tolerances and far, far better quality with far les back lash. The result are gears that are MUCH quieter than previously available parts. PLUS they offer somethinmg ike 9 different ratios using a common idler gear. Where JK could only offer a limited 2 ratios with the same idler and drop gear, MSC can offer a minium of 3.
Posted 16 October 2009 - 11:25 AM
I guess having tinnitus makes it so much worse. Now, did I get tinnitus from years of angle grinding, working inside aircraft rivetting as an apprentice, discos ( as a younger guy!), rallying in noisy cars. I guess that's a 'Yes', so beware of all those things, you younger guys.
Posted 16 October 2009 - 12:42 PM
Posted 16 October 2009 - 02:17 PM
