Been paying my brothers copy, unfortunatly not online, but does anyone know the best drift setup and upgrades list for the Silvia S15? I can find a Forza 2 setup but not for 3.
I try'd the carbon look aswell on my bonnet, made a load of little squares in the make a group bit, but i cant make them small enough to look right. Not without exceeding the complexity limit anyways.
Any help on either?
i could make you an absolute beast of a drifter if you had an S14. I'm going to start experimenting with the S15 soon, see if the same trick works.
As for the carbon fibre effect, i was comfortably under the limit. I think the top section was at around 600/1000, and the front and rear bumpers 250/500.
Calman, if you go to the race vinyls section (i think) there should be a vinyl shape that looks like chicken wire. all you do it shrink that down, reduce transparency, and multiply about 1000 times
