What Needle To Use
Posted 27 October 2009 - 03:11 AM
Can someone look in the winsu and tellme the best 3 needles, and performance quotes???
I have this configuration:
998cc, 12g295 head, hif38 with kone, freeflow exhaust, 45d distributor with electronic ignition, 3.44 final drive, standar cam, 6 blade fan, standar rockers...
Thanks a lot
Posted 27 October 2009 - 11:42 AM
Posted 27 October 2009 - 11:53 AM
The top three needles it recommends are:
A?D
A?K
A?U
Performance Data:
54.1 bhp at the flywheel
41.9 bhp at the wheels
56.8 lb/ft of torque
0-60 mph in 13.3 secs
Hope this helps,
Robbie
Edited by RobbieH241_HEH, 27 October 2009 - 12:02 PM.
Posted 27 October 2009 - 11:51 PM
AAU
AAA
AAM
Personally i'd try AAM.
And yes, hif38 and hs4 carbs needles are the same.
Edited by jaydee, 27 October 2009 - 11:53 PM.
Posted 27 October 2009 - 11:54 PM
Posted 27 October 2009 - 11:55 PM
Posted 28 October 2009 - 12:12 AM
Checking the spark plugs can be a good idea, they will also show you if timing is correct (you'll notice a color change where the ground strap bends).
You can always use a gas tester to set mixture at 2,5 co at about 1000rpm.
Posted 28 October 2009 - 03:34 AM
I'm using 20w50 oil in the carb, is good over 3500RPM but the response is not good below that
Edited by FailleARQ, 28 October 2009 - 03:36 AM.
Posted 28 October 2009 - 07:12 PM
Is it good??I'm using 20w50 oil in the carb, is good over 3500RPM but the response is not good below that
Posted 28 October 2009 - 08:40 PM
I have found the information above VERY interesting but my application is "non-Mini". Roy, if you're still reading this thread I'd appreciate your comments regarding what I'm working on. I've recently switched to an HS4 carb on my 1300cc Triumph (Spitfire). This carb was never stock for the U.S. version of that engine so I was planning on using whatever needle Triumph used on the Toledo which did use the HS4. The "stock" needle for the Toledo was even leaner than the AAK needle mentioned above so I'm surprised to see that a 998 Mini can operate well with the much richer AAA. I'm very tempted now to order an AAA needle and try it on the Triumph. This might allow me to run the jet higher than it is currently set.
Posted 28 October 2009 - 10:25 PM
I have just had a play with dashpot oils, the 3 in 1 oil is too thin, so im running on 10W40 and it seems spot on
Posted 28 October 2009 - 10:35 PM
Posted 28 October 2009 - 11:54 PM
The traveller is idling too high (1500), and seems to have very flat response from light to nearly full throttle, then all the performance falls in the last little bit of throttle travel. A local LBC mechanic rode in the car with me and said it was behaving as it it was rich at low end and lean at the top.
I believe the needle in right now is an AAU.
Posted 29 October 2009 - 01:01 AM
Alan... I wasn't aware you visited this board. Belated welcome.
Posted 29 October 2009 - 01:57 AM
