Straight Through Exhaust
22 replies to this topic
#1 22068
22068
  • 36 posts
  • Local Club: Dont have one
Posted 28 October 2009 - 10:44 AM
what diiferences would it make?
#2 davethemini1293
davethemini1293
  • 105 posts
Posted 28 October 2009 - 10:59 AM
you'l have a nice headache
#3 chappy
chappy
  • 1,253 posts
Posted 28 October 2009 - 04:22 PM
i'll add to your answers as the previous one was very helpful :s
straight through exhaust will give you better gas flow increasing performance slightly, to get a better increase in performance it'd make sense to add a high flow air filter.
hope that helps
Sam
Edit,
and you do have a local club!!!! theres a few!
type in 'northamptonshire MOC' into google, the first one is the northants moc forum! Join up, say hello. If you need a hand with anything, Pm and i'll do my best (also have some contacts for you)
Edited by chappy, 28 October 2009 - 04:24 PM.
#4 daemonchild
daemonchild
  • 2,341 posts
  • Local Club: Unknown
Posted 28 October 2009 - 04:24 PM
You'll still need a cat though if this is an injection mini won't you?
#5 Calman
Calman
  • 1,674 posts
Posted 28 October 2009 - 04:28 PM
As above really. What year is yours because if its and earlier car then you can push the Co2 levels a bit higher i think.
#6 chappy
chappy
  • 1,253 posts
you will for MOT, can always get a de-cat pipe, bolt it on for the year, the bolt the cat back on at MOT time :lol:
#7 sambarnes
sambarnes
  • 209 posts
Posted 28 October 2009 - 04:32 PM
My plan is to get a pipe to replace my cat (you can get them from minisport).
While im on the topic, i was wondering whether or not you can fit an LCB to an MPi/SPi??
sam
#8 davethemini1293
davethemini1293
  • 105 posts
Posted 28 October 2009 - 05:24 PM
hope that helps
Sam
Edit,
:lol:
did you mean without a silencer?
then yes it will do your head in,
if so this will do you,or your car no favours,
rover didn't spen x amount designing an exhaust for your engine just to put a straight thru pipe on it.... :lol:
kids.....
if you meant just a de-cat pipe then it will gain a little power,
#9 bluedragon
bluedragon
  • 287 posts
Posted 28 October 2009 - 09:30 PM
Is this an MPI? If it's a twin point and unmodified otherwise, a straight pipe will add very little other than noise. The engine is constrained for airflow and fuel flow, not exhaust flow. If you've got a big head and cam/rockers, basically pushing it above a true 85 hp (for reference, the vast majority of "90 bhp" kits for MPI's deliver between 75-80 "true" hp in practice) then the exhaust can be constraining.
But it's hard to go over 85 true hp on an MPI due to the fuelling limitations of the ECU, indeed, I would count myself fortunate to be pulling 80 bhp from a modded MPI with stock ECU. (and there is no easy replacement for the stock ECU, but that's another question entirely...)
#10 chappy
chappy
  • 1,253 posts
Posted 28 October 2009 - 09:33 PM
a straight through exhaust system, is the design. :lol: :)
straight through, means that the silencers have a pipe that literally goes straight through it and lots of holes on the inner pipe which then absorbs the exhaust noise without decreasing gas flow so much as a normal silencer.
Rover didn't put a stage 1 kit on their minis, but people do, and people get a good power increase from it.
Rover didn't manufacture adjustable bottom arms and tie bars as standard, but people put them on.... why? because its a modification to make things better/more reliable
Although i do agree, not putting a silencer on its pretty pointless... (unless your part of force racing :lol:)
sam
you certainly can, the only difference is the boss for the lamda sensor on the injection LCBs.
hope that helps
Sam
Edited by chappy, 28 October 2009 - 09:35 PM.
#11 MiniAlex
MiniAlex
  • 734 posts
  • Local Club: Mini's N Oatcakes
Posted 28 October 2009 - 09:47 PM
sam
hope that helps
Sam
I really want to get rid of my Cat but someone just told me on a post that I have only just posted! .. that if you get rid of the cat and it was made with one u can get pulled over. The vosa are pulling cars over and doing checks, just talking to my mate and he was pulled by the police for a check (safety) but they an check ur emissions too! I really want to get rid of the cat, but some people have said that it's best to keep the cat on, so that if u get pulled u pass the check. I was thinking that I could just keep the cat off for the year and just pu it back on for the mot?
#12 Calman
Calman
  • 1,674 posts
Posted 28 October 2009 - 09:51 PM
to be honest i can see the plods pulling a classic "Because they're all eco nightmares" :lol:
#13 MiniAlex
MiniAlex
  • 734 posts
Posted 28 October 2009 - 09:53 PM
Exactly lol. Well I am getting the pipe, stuff them lol. If they pull me over I will just say that i never knew :lol: They only will give you a warning anyway!
#14 chappy
chappy
  • 1,253 posts
Posted 28 October 2009 - 09:57 PM
i doubt that police will have a gas meter in the back of the car...
doubt they'd pull you over just to check your emissions.
#15 MiniAlex
MiniAlex
  • 734 posts
Posted 28 October 2009 - 10:01 PM
Apparently VOSA pull you over now a days! :?
