Wiring 'savage' Switches. Easy Or Difficult?
Posted 03 November 2009 - 12:06 AM
Posted 03 November 2009 - 12:12 AM
they all state they are latching switches on ebay, even the brake test switch. is this right or is 'latching switch' just a term used.
Edited by Darkscamp, 03 November 2009 - 12:43 AM.
Posted 03 November 2009 - 12:17 AM
Posted 03 November 2009 - 01:04 AM
If you want to me more fancy (like I am) you can wire it up so when the lights are on the LED eluminates with low/dim light and when you flick the switch it glows fully. To do this you need some 4K resisters and diods. Basically you draw a feed from the instrument light pass it through the diod and LED and then you insert a diod in the feed for LED. The diod will ensure that power does not passthrough to the other side. Here is a pic done by someone else on the WSCC site.
You can get more info here.
Posted 03 November 2009 - 11:28 AM
I am fitting a set of these to my car. You can do them as a straight swap with the output split in to 2, one for the LED and one for the device.
That's a nice idea. Stick a capacitor in parallel with the LED and it'll fade on and off too
Posted 03 November 2009 - 11:48 AM
Posted 03 November 2009 - 03:36 PM
Dan
Edited by mini-man-dan, 03 November 2009 - 03:36 PM.
Posted 03 November 2009 - 10:05 PM
Hmm ok. I think that's a bit beyond me, really not keen on electrics! How much do you reckon a auto-electrician would charge to do it? I haven't got a clue!
Dan
I am not that good in electricals either, I just followed the guide I linked to and basically you need to solder the components together. It is not that dificult realy, it took me around 2 hours to figure out which way around each component goes, then started soldering them together, overall it took me 6 hours to prep 8 switchs (inc testing each).
Here are some pics of the setup:
Side lights on so the switch is illuminated dimly:
When the switch turned on:
Complete setup:
If you need it I can do a small guide with large pics to show you how to do it.
Posted 04 November 2009 - 09:53 AM
Edited by mini-man-dan, 04 November 2009 - 09:53 AM.
Posted 05 November 2009 - 09:40 AM
Posted 05 November 2009 - 12:21 PM
hopefully when its done, the powers that be will pin it for future users
Posted 05 November 2009 - 04:35 PM
Okay, should be able to get something together by tomorrow. I am partially colour blind as well and I rely on the family and sticker tapes to help with the colours.
And thanks very much. Will make all the difference to the interior I think
If the hazard is all too confusing, you could run that on a normal rocker switch and hide it to the right of the steering wheel on one of them little panels as it isn't so noticeable all in black. Then buy one of the replacement panels for the centre from Minteriors (I think that's who sell them) which are for the centre for Savage switches, with the right hole size in.
Dan
Edited by mini-man-dan, 05 November 2009 - 04:38 PM.
Posted 05 November 2009 - 06:04 PM
how it is wired there is exactly what i was going to do, and i even had the cap to get it to dim
im an electrical engineer so do a lot of stuff like this, modding circuit boards
id help you out with the colour blindness but i have a sick sense of humour
'yep yep thats earth, muhahaha)
Posted 05 November 2009 - 06:06 PM
if that makes sense
Posted 05 November 2009 - 06:22 PM
