Im currently looking for a block and pistons for my supercharged motor. Im thinking of pushing the charger to knock out about 15 psi of boost as ive heard you can when you water cool the Eaton. What pistons and chamber cc should I use? Ive seen one of the Eaton converted cars knocking out 180bhp with a c/r of 7.5:1. As most of you lot are experts in the feild of turboing any of your help will be much appreciated.
What c/r should I run?
Oldskoolbaby
, Oct 09 2005 07:43 PM
2 replies to this topic
Posted 09 October 2005 - 07:43 PM
Posted 11 October 2005 - 10:41 PM
i wouldnt have thought you'd need to go below 8:1 with a decent RR setup...only trouble you'll have is high inlet temps which will limit the boost you can run.
Posted 11 October 2005 - 10:54 PM
Yeah with a suck through setup you've no option to intercool, so as bud says this will limit the amount of useable boost available. Most Turbo motors running about 15psi will be around the 8.1-1 compression area. I run 7.6.1 on my motor but this is built to run 20psi+.
Phil.
Phil.
