Inner Steering Colum Mk3 Walkthough Please!
20 replies to this topic
#16 Gingerjoe
Gingerjoe
  • 1,908 posts
  • Local Club: Tmf
Posted 08 November 2009 - 09:57 PM
hmm, when I did it, I took the carpet up on both sides, the passanger side & driver side, I undid all the bolts, fitted the drop bracket, ajusted to where I wnated & then tightened all the nuts up again. both sides.
#17 Min E
Min E
  • 226 posts
Posted 09 November 2009 - 12:41 AM
OK.
Back to square 1.
If you adjusted the rack and have not adjusted the steering hight sinse then everything should be alright.
You said at the start that there was a crunch and then the steering wheel turned but the wheels didn't.
Can you turn the steering wheel all the way round without the road wheels moving or is it just loose for a bit of the turn
You shoud not be able to turn it all the way if the pinch bolt (a the bottom of the column) is in place because it should lock up on the splines. There is only one place in the spigot that the bolt will fit.
Check if the pinch bolt has dropped out. If it has you might just have got away with it but I would strongly recommend that you take the column out and inspect the condition of the splines in it before just bolting it back. If they show any sgn of wear at all, it's not worth the risk. Replace it.
Edited by MINY, 09 November 2009 - 12:42 AM.
#18 Gingerjoe
Gingerjoe
  • 1,908 posts
  • Local Club: Tmf
Posted 09 November 2009 - 10:18 AM
just got the spline though today, got the haynes manual out, cuppa tea, then gonna give it a go. tar!
#19 jayare
jayare
  • 2,093 posts
Posted 09 November 2009 - 11:05 AM
Unfortunately that's not 100% true any more - a lot of aftermarket racks come with a pinch-bolt groove which runs all the way round so the column can be fitted in any orientation.
JR
#20 Gingerjoe
Gingerjoe
  • 1,908 posts
  • Local Club: Tmf
Posted 09 November 2009 - 11:29 AM
the spline ive bough is like moulded in with the hole spline, on my one, it looks seperate, everythings off apart fromt he spline, cant get the bloody thing out, so tea break & g onna have another go inabit. whats the easist way to remove the spline & should the spline still spin, the bolts been taken out, & its spinning around with I turn it, surely that just tells you the teeth have gone? I just hope theyve got on the inner colum & not the rack :-
#21 Gingerjoe
Gingerjoe
  • 1,908 posts
  • Local Club: Tmf
Posted 09 November 2009 - 12:50 PM
ive done it, inner colum splines where MUNCHED. all sorted, thanks for all your help, more than much appreciated
