Negative Camber In The Rear
Posted 05 November 2009 - 10:26 PM
Posted 05 November 2009 - 10:30 PM
(although, negative camber isnt for show or style, if set up properly it can greatly increase grip/handling/road holding.)
sam
Posted 06 November 2009 - 12:26 AM
Posted 06 November 2009 - 08:14 PM
As above, whats the car gonna be used for? You'll notice MORE tyre wear with neg camber so if its primalary a daily driver you'll need to keep an eye on your side wear
Its a weekend car...Im not looking for massive camber...-1° to -1.5°...by the way where is a good source for the brackets? Im in Canada.
Edited by dipstick, 06 November 2009 - 08:21 PM.
Posted 06 November 2009 - 08:33 PM
do it makes loads of difference
Posted 08 November 2009 - 01:53 AM
Posted 09 November 2009 - 10:46 AM
Go for KAD rear camber brackets, im sure they'd ship them out to you.
If not minisport ones are reasonably good. You'd need to get it setup properly though which ever brackets you choose.
Sam
Posted 09 November 2009 - 02:55 PM
Sit the car on a flat and smooth surface, like inside your workshop and place the board against the tyre vertically and in line with the rear wheel centre. Now, using a steel rule, measure from the lowest point of the wheel rim to the edge of the board and do the same at the top. The difference between these two dimensions is the amount of camber over the wheel diameter. From this you can work out the angle and filoe the slot to suit. In fact you don't need to roll the car back and forward as the rear radius arms are true training arms and the wheel moves vertically.
For a road car the ideal settings are between 0.25 degrees and 0.5 degrees negative.
For reference, to get the best handling, the rear wheels should toe-in by between 1/16" and 1/8".
Posted 09 November 2009 - 04:35 PM
To measure the rear camber I use a piece of 1/4" thick ply board about 20" square. It has to be exactly square.
Brackets it is....thanks for the Info guys...really appreciate it...has anybody have any experience with minimania.com.
http://www.minimania...9/InvDetail.cfm (fixed)
http://www.minimania...3/InvDetail.cfm (adjustable)
Posted 09 November 2009 - 10:19 PM
Nar too much in my experience.. zero to 1/16" far better.
Posted 09 November 2009 - 10:42 PM
Posted 09 November 2009 - 10:45 PM
Posted 09 November 2009 - 11:23 PM
Hows that then?and it ends up far stronger than some of the over-priced brackets which are poor weak things
Posted 09 November 2009 - 11:31 PM
since when has there ever had to be a reason other than his opinion Dave?Hows that then?and it ends up far stronger than some of the over-priced brackets which are poor weak things
Posted 09 November 2009 - 11:42 PM
I think those aftermarket brackets are pointless, once you have set it you dont need to adjust it anymore, they look crap and tinny, just file it out a bit at a time until it is right!
Edited by R1minimagic, 09 November 2009 - 11:45 PM.
