From practical experience of these brackets i can say that:
the aftermarket fully adjustable brackets - I have *never* known the adjustments to slip... I have used the KAD, minispares and minisport ones for 10+years for road, track, and rallycross. These cars have taken side swipes, been given plenty of 'air', etc. Have bent radius arms and the brackets havent shifted.
The little nut and bolt that is often thought 'holds the adjustment' doesnt (the KAD and minisport ones dont use this). that little nut and bolt is there to lock the adjuster should you wish to remove the bracket in the future for radius arm work.
The tightness of the pivot shaft nut holds the adjustment fine (held against the serations.
Granted the downside of them is that they dont look the prettiest things in the world (though the KAD ones are nice
Have also seen the minispares and minisport brackets break at the welds - though this could well be to do with amount of toe out that was dialled into the car at the time and the forces that impose.
ttfn
