been building up my supercharger kit & getting to the bussiness end of the build. I have got the option of useing mg metro turbo carb or an mg metro carb both 1" 3/4. i know the needles are different & i was going to use the turbo needle to get me going. apart from that what eles is differant (internaly) & which would be best to use? i was thinking the mg metro carb as its still suck through set up?
Also have turbo dissy & mg metro dissy, again which one?
joe
Carbs For Supercharger
joe90
, Nov 06 2009 08:39 PM
1 reply to this topic
Posted 06 November 2009 - 08:39 PM
Posted 07 November 2009 - 12:54 PM
As it's a suck through setup & the carb only ever sees vacuum then it doesn't matter which carb you use. As for a dizzy, neither one is going to be correct, but I'd use the Turbo one & set it so the total advance doesn't exceed 25deg. This should be safe to get you running & to a rolling road.
