Amp Behaving Badly!
dwealds
, Nov 12 2009 06:32 PM
44 replies to this topic
#31
Posted 14 November 2009 - 05:51 PM
check the rca cables............ should have 2 sets. make sure you are not on the sub output from the head unit
#32
Posted 14 November 2009 - 06:07 PM
There are only 2 RCA outputs on the back of the HU, 1 red and 1 white. I have put RCA doublers in at the amp end so that all the inputs to the amp are filled
#33
Posted 14 November 2009 - 06:39 PM
ahhhh, so its running from a single output
problem lies with the crossover settings somewhere then
just take your time and check and double check then if you can, get a photo of it
#34
Posted 14 November 2009 - 06:40 PM
I just had a good look through the HU manual and something dawned on me. Is it possible that the Pre outs for the RCAs on the back of the HU are just for the sub output and not high end?
Then I thought of a way to sort this out but wanted peoples opinions: Could I use the original outputs from the HU to the original speakers in the back (they were 6" 3-ways) and put them into the HI-LEVEL inputs on the amp and continue to use the pre out RCAs to power the sub through the amp?
Sorry if that doesn't make much sense
#35
Posted 14 November 2009 - 06:48 PM
give it a try
would rule out speaker problems
#36
Posted 14 November 2009 - 06:51 PM
The speakers arnt the problem, I connected the 6.5" ones to the original outputs from the HU and they worked fine. Would it just be easier to buy a new HU with more pre outs!? lol This is so frustrating
#37
Posted 14 November 2009 - 07:15 PM
its up to you mate its your hard earned cash but you can get to great deals from ebay with 3 outputs in internal active crossovers for not much moola
#38
Posted 14 November 2009 - 07:18 PM
Bit of a noob question again but what are active crossovers?
#39
Posted 14 November 2009 - 07:41 PM
electronically seperate frequencies so sub mid and high only recieve them
head unit==active crossover==sub input amplifier==subwoofer
== mid input amplifier==midrange
== high input amplifier==tweeters
each channel of the amp has a dedicated frequency basically
#40
Posted 14 November 2009 - 07:47 PM
Ah right I get ya, cheers
#41
Posted 14 November 2009 - 07:49 PM
means more amps needed, more expence but the sub part is usefull
me i prefer making my own passive crossovers, more fun sat with a pile of capacitors and coils working out what combination is best
#42
Posted 14 November 2009 - 07:51 PM
I have done a BTEC national course in electric and electronic engineering and i wouldn't have a clue where to start building a crossover useful course
#43
Posted 15 November 2009 - 01:57 PM
Right, I tried my idea of putting the hi-level inputs in from the HU as well and it worked an absolute treat!! Almost blew my head off as the volume was up loud from where i took the old knackered speakers out. So now apart from being partially deaf im very happy
Thanks for all the help everyone, much appreciated!!
#44
Posted 15 November 2009 - 03:35 PM
fantastic, your pre out must be a sub one i suppose
#45
Posted 15 November 2009 - 05:23 PM
Yeah I would guess so, nice to have it done finally
