1275 Mg Metro Engine Rebuild Shopping List
#16
Posted 14 December 2009 - 12:24 AM
#17
Posted 14 December 2009 - 12:45 AM
#18
Posted 14 December 2009 - 01:28 AM
The head will need machining to take hardened seats. I wouldn't bother as it'd be relatively easy to do later, ideally while cutting triple angle seats and fitting new guides.
#19
Posted 14 December 2009 - 09:13 AM
I did the same job as you over last winter- MG Metro block and head, bored +.060 with 21253 pistons, HIF44, MG Metro cam etc, etc. By the time I had also bought a new 2-core rad, alternator, oil pump, water pump, clutch etc I was well over £1000, and that was doing most of the work myself. I am really happy with the outcome but looking back it would have been cheaper to buy a short block kit and go that route. I just didn't realise that at the start!
Don't forget cam bearings and followers (if pitted). Re unleaded, I just add some additive every now and again and run it on 99Ron. Seems to love it!
Good luck!
#20
Posted 14 December 2009 - 10:47 AM
#21
Posted 14 December 2009 - 01:43 PM
How much will the Micra engine job cost??
#22
Posted 15 December 2009 - 08:56 AM
Hey guys,
So i am upgrading from my 998 engine to a mg metro 1275 i have aquired. This is my shopping list of things to get to do it, tools as well as parts! Hopefully i can get some opinions and advice on parts to use, and make sure i buy everything i need in one bulk lot!
Decision:
rebore (+60)
regrind crank
Tools:
Piston Ring Compressor
Valve spring compressor
Parts:
Fuel Pump - use the one from my 998
Water pump
Carb (i already have some twin hs2s?)
Exhaust/manifold(what bits can i use from my current 998 maniflow exhaust?)
Gaskets
Piston Rings
Big Ends
Main Bearings
Valves - will use old ones in there and lap them to new seats
Valve Springs - new ones needed?
Hardened Valve seats (to convert to unleaded)
Silicon hoses
Oil Pump
valve stem seals
Thanks guys
Ian
Apologies to those that have already poted, I haven't read all of them - Ian, it may be worth you getting hold of at least one recent issue of Mini Mag where I have covered an engine re-buils, what is likely to be needed and the parts list/prices (issue 165). The next issue (166) coevrs alretnative parts to up-grade the engone, then sorting the head out (issue 167) and finally what happens when you strap a set of 1.5 rockers on your standard engine (issue 168). Alternatively grab a copy of my CD 'Mini Expert: Issue 1' from my website - fulley engine buikld how to on their and some otions for up-grading the engine. Also covers hearbox and clutch. Is this a shameless punt? Not really - haven't seen this information anywhere else. KC
#23
Posted 15 December 2009 - 11:25 AM
Hey guys,
Decision:
rebore (+60)
regrind crank
Tools:
Parts:
Water pump
Gaskets
Piston Rings
Big Ends
Main Bearings
Silicon hoses
Oil Pump
valve stem seals
Thanks guys
Ian
thanks for the advice, i am currently re considering until i have some more funds!
http://www.theminifo...p;#entry1671804
any advice in that topic ?
