Wiring A Kenwood Headunit - Yellow Wire?
7 replies to this topic
#1 daemonchild
daemonchild
  • 2,341 posts
  • Local Club: Unknown
Posted 15 November 2009 - 10:00 PM
As per the title, I was given a freebie Kenwood KRC-357L headunit.
It's old, but it was free. :dontgetit:
There are some self explanatory wires (front-left, rear-right etc).
And there are three wires that are unlabelled.
Red -- guessing +ve 12volt feed unswitched.
Black -- guessing earth
Yellow -- very much guessing +ve 12volt ignition switched?
Does this sound sensible?
There are no inline fuses, but I think I'll add some.
I got it at 8pm tonight, so have had no chance to play.
Thanks!
#2 2lrminivan
2lrminivan
  • 276 posts
Posted 15 November 2009 - 10:21 PM
yep u correct
u can change the yellow and red round if it does not keep the memory
there should be a fuse in the back near the wire plug thats all u need
#3 daemonchild
daemonchild
  • 2,341 posts
Posted 15 November 2009 - 10:23 PM
yep u correct
Thanks! Good stuff.
I hadn't spotted that fuse... so straight to the battery then.
Awesome stuff - will be fitted in a jiffy.
#4 Darkscamp
Darkscamp
    Drives the 'Thing'
  • 1,475 posts
  • Local Club: Lone Ranger
Posted 15 November 2009 - 10:24 PM
red should be perm live, yellow should be 12v ignition live, black is earth.
when connected up, turn you ignition on, store a radio station and then turn it off and then on again. if when turning it back on, it fails to store the radio station in memory, turn it off and swap the red and yellow around.
kenwood normally have a fuse in the back of the head unit, but depending on what circuit you fit it on, an extra fuse may be a good idea to be safe.
#5 dsgoody
dsgoody
  • 519 posts
  • Local Club: Gert Lush Minis
Posted 15 November 2009 - 10:29 PM
I know it's the opposite from the logical way round but Red is Switched Live, Yellow is Constant Live and Black is Earth.
#6 pbrain
pbrain
  • 431 posts
  • Local Club: not yet
Posted 15 November 2009 - 11:27 PM
i tend to connect red & yellow to permanent live, just so i can listen to the HU with the engine switched off (ideal when waiting for the other half shopping :dontgetit: )
#7 Jimmy Hat
Jimmy Hat
  • 960 posts
Posted 15 November 2009 - 11:32 PM
Seems sensible but i'd be forgetting to turn it off. I just wired mine to first ignition stage and I can do the same thing :dontgetit:
Edited by Jimmy Hat, 15 November 2009 - 11:34 PM.
#8 daemonchild
daemonchild
  • 2,341 posts
Posted 17 November 2009 - 06:48 PM
All done fellas - thanks :withstupid:
Now I have tooooones!
