Confirmation Please
Posted 17 November 2009 - 09:36 AM
I'd just like confirmation that it's the correct one for an SPI, ie hangers/cat back etc.
(I know, i know, 3" bore/power loss. 1.75/power gain etc. I don't care, they look and sound so sweet. )
Posted 17 November 2009 - 11:11 AM
That's not a 3" bore pipe from what I can tell, just the tip is 3". So you shouldn't have any power loss at all! I could be wrong though.
Posted 17 November 2009 - 11:29 AM
But remember, it's your car no-one else's, so as you see fit (excludes safety related things tho )
Posted 17 November 2009 - 11:58 AM
@Newdawn. I believe that's the case about power loss from a 3" tailpipe, but as you also state most wisely, it's my car.
May you both get to heaven half an hour before the devil knows you're dead.
Posted 17 November 2009 - 07:18 PM
Posted 17 November 2009 - 08:49 PM
Just had a proper look at the link you put and if you get that system it will be from lcb back removing the cat totally, but you need to be able to put the cat back in for the MOT and with that system you wont be able to. What you want is http://www.minisport...MSLPM41-44.html which if I'm reading it correctly is the Playmini large bore side exit cat back system which is the one I have got, looks right from the photo but i would ring and check it is cat back. If you then want to remove the cat you can buy a cat removal pipe, which literally replaces the cat directly making it easy to put it back on for the MOT.
Posted 18 November 2009 - 08:13 AM
I have a Playmini large bore side exit cat back system on my spi Mini, along with a Maniflow lcb and de-cat pipe. I have ran this system for 4yrs no problems, actually I think its great, love the sound, will soon be running this system on both my spi minis. Only thing I have to do is replace the cat for the MOT because i have chosen to use a de-cat pipe.
Ah yes, 'tis the wrong one. I'd meant to link to the cat back one. Well spotted.
